Question about Acer G185HAb 19" LCD Monitor
It makes a blue screen every 20 minutes and says anti theft alert so i unplug it for about 5 minutes and then it works and does it again
    Problem Solver:
  • 6 Answers
To turn off anti-theft mode:
1) Turn off the monitor
2) Press and hold the menu button
3) Turn on the monitor
Release all the buttons
that should disable the anti theft mode
Posted on Mar 13, 2011
  • 1 more comment
  • aricapat Mar 25, 2011
    thank you so much that helped alot i was about to pull out what little hair i have :)
  • hardyhar6 Apr 01, 2011
    I'm having the same problem (with the blue screen) - my question is: which one is the menu button? I have a series of 5 buttons underneath the screen (to the right, along the bottom edge) but they are not marked at all. Can you help?
  • a j m i l l e r Apr 01, 2011
    on this model it should be the 2nd button on the left but there is 3 different models of this monitor with the same badge on the back , if its not the 2nd button turn on the monitor and try out the buttons untill you get the menu up
Reset alarm system
Disconnect the battery for @20 minutes. Then try again. Sounds like the anti theft is shutting the car down. You can also try locking and unlocking the car with the key fob 5 times ending with the vehicle unlocked. Try starting it again. If that does not fix it the chassis module is faulty or there is a short in the connector to it.
Jul 30, 2014 | 2001 Chrysler Town & Country
Anti theft strating rrouble
Turn key in the on position without starting car.anti theft light will blink fir 15 to 20 minutes.when light stops blinking turn to off position.wait 5 minutes. Then start car. Found this on a u tube video. And it does work.
Jun 06, 2014 | 2003 Chevrolet Malibu
Anti-Theft device is so good that WE can't even steal our own car!
The dealer are the only ones that can disble the anti-theft device with the Tech2,but thepblemou hve ,it souns tome likethe Crank shaft pos sensor, common problem for that year model, agter you let the engine cool down a little bit the engine will start again.
Jan 29, 2013 | 2000 Saab 9-5
The car wont start, the brake pedal is locked like the anti-theft is active, the anti theft light is flashing when the keys are in the ignition. when i try to turn it on it doesnt turn over, just makes...
TRY REPROGRAM KEY .PUT KEY IN IGNITION SWITCH TURN IGNITION SWITCH ON POSITION 20 SECONDS DONT START ENGINE WAIT 20 SECONDS TURN OFF SWITCH THEN TURN SWITCH BACK ON 20 SECONDS WATCH THE THEFT SECURITY LIGHT BLINKING.WHEN THEFT STOP BLINKING VECHICLE WILL CRANK.IF LIGHT STILL BLINKING.TRY FEW MORE TIMES KEY IN SWITCH ON POSITION FOR 20 SECONDS.MAKE SURE YOU HAVE THE CORRECT CAR KEYS IN SWITCH IF NOT WRONG SET OF CAR KEYS WILL SET OFF THEFT SECURITY SYSTEM.IF KEY RESETTING TRICK DONT WORK.CHECK BATTERY POWER MAKE SURE YOUR BATTERY HAS 12.5 VOLTS AND CHECK SECURITY THEFT FUSE.IF ALL LOOKS GOOD YOUR SECURITY HAS TO BE CHECKED OUT AT THE DEALERSHIP.
Oct 08, 2010 | 2006 Ford Fusion
I have a 2001 mercury sable and the anti theft is on and I can't start my car. will disconnecting the battery reset it?
Yes, keep it disconnected for at least 10 minutes. Also make sure your Battery is good. Sometimes the Anti-theft is sensitive to Battery voltage and will not connect the internal parts to allow a start.
If you have a Keypad, enter the Security Code on the Keypad and turn the Ignition Key within 5 to 10 seconds to start it.
Sep 30, 2010 | 2001 Mercury Sable
I would like to disarm anti-theft system
On my 1998 Exlorer Sport there is a set of 5 wires in a yellow sheath running from the ignition module to a brown connection point/harness in a very uncomfortable position directly under the steering column above the pedals.
I unplugged the connection at this point. This stopped the key-in-ignition chiming (part of the anti-theft feature) but I still get the chime alerts for headlights left on, initial chime when the key is turned. The pinging, or ringing chime comes from the multifunction computer located under the dash behind the radio.
Hope this help.
Apr 06, 2010 | 2000 Ford Windstar
Car won't tunrover
try this -make sure battery is good and fully charged,then TURN KEY ON (DONT CRANK) AND LEAVE ON FOR ABOUT 10-20 MINUTES. TURN KEY OFF FOR 5-10 MINUTES AND THEN TURN ON AGAIN FOR 5-10 MINUTES AND THEN TURN KEY OFF AGAIN. NOW TRY CRANKING ENGINE--- IM GOING ON MEMORY/MECHANICAL EXPERIENCE WITHOUT THE BENEFIT OF THE OWNERS MANUAL IN FRONT OF ME. IF U HAVE THE MANUAL LOOK IN THE INDEX UNDER SECURITY LIGHT OR ANTI-THEFT FOR RESET PROCEDURE. get back to me if you need more help.
Sep 14, 2009 | 1996 Pontiac Grand Prix
Ford explorer 2003 clock is running at approx double speed
have you tried resetting it ? basically unplug the battery for about ten minutes... also make sure you have the anti-theft code to reactivate the radio when you power it back up again (if it requires a code)
Robert
Mar 01, 2009 | 2002 Ford Explorer
Anti theft light comes on when driving
no cutoff switch!! try this turn key to on, do not start car. let sit for about 30 minutes, after 30 minutes, turn key off. wait 15 seconds and try to start car. this should reset anti theft system.
Feb 20, 2009 | 2000 Chevrolet Malibu
Acer G185HAb 19" LCD Monitor Logo
389 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
