Question about Airstrike Bell 1800 Floor Bike Pump
The tubing that leads from the pump to the tire is broken off right at the base? Can it be repaired? HOW?
    Brigadier General:
  • 8,546 Answers
Most Bike Shops carry repair kits for common pump brands and I wouldn't be surprised if some cross brand parts would work. eBay has many for sale.
"floor pump hose"
You might even be able to go to an automotive supply store and get some pressure hose yourself real cheap.
Posted on Mar 13, 2011
I am trying to find the right tube to change the tire.
tubes are measured based on your wheel sizes. if look on the wall of the tire it will have a size. this is the size of the tube you need to buy.
May 02, 2011 | Cycling
How sohuld I take care from my bikes tires?
It is important to get your tires checked from time to time. Second only to wear and tear resulting from dirt,the biggest problem cyclist encounter is with tires. Many inexperienced cyclists tend to ignore the tires. This can lead to dangerous issues. Bicycles tubes are made from a porpus type of rubber called buytl rubber, which allows air to slowly seep out. If tires are not regularly re-inflated to proper volume, they will be to soft. Apart from being much harder to pedal with, soft tires also lead to rim, tube and bicycle wheel damage.Soft tires wear out much faster, and can pop unexpectedly,leaving you stranded. To ensure that tires are propely inflated, pump up road bike tires before every ride, and check mountain bike tires every week. Use an effective pump, ideally ,a bicycle pump with a build in gauge, and observe your bicylce manufaturers information about recommended tire pressure.
Dec 21, 2010 | Cycling
How do a fix a flat tire on my weedeater riding mower? 13hp 38 series
I suggest a trip to the auto parts store. Buy a tubless tire repair kit. Ask the sales person how to do the job (it is easy). Repair the tire on the rim and try to do it without the bead coming off the rim. Next, take an air pump and pump it up! If the tire has a tube, you must take the tire off the rim and repair the tube...Good luck...Lee
Jul 17, 2010 | Garden
Fix for broken tubing leading into filter bag?
You can replace the black tubing. There is no need to get a new vacuum. You can find the parts you need by following the link below.
http://www.usavacuum.com/Kirby-Generation-3-s/145.htm
Make sure to leave positive feedback.
Thanks USAVACUUM.COM
Mar 05, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I have a 2001 saturn L100 that has a code of PO404. Is this my EGR sensor? If so where is it located and can I clean it or does it have to be repaired?
EGR Valve is on the intake manifold on the right side rear by the shock tower. It's round, has a base similar to a diamond shape, and has a steel tube leading up to it's base area on the back of the rear intake manifold. You can take it off and clean it out with throttle body cleaner, and clean the tube, but I've never seen one plugged. If it's indeed bad then I'd replace it and get a new gasket. If you're not sure how to check it then you should reask and clarify that.
BTW... just because there's a code doesn't mean the valve is broken. Could be an electrical issue. Again, check and clarify please.
Oct 06, 2009 | 2001 Saturn L-Series
Unrepairable inner tube
True Goo inner tube sealant! Go to a bicycle repair shop with your stroller, and honestly, have all the tires shot up with this goo and then pumped up to your desired firmness...
I have a different jogging stroller, but I know the Maxi Cosi's Mura has the same air pump access as other bicycle tires like my jogger does. I kept getting flats, and this goo has kept my tires firm for 6 years now, I used to have to bring along a pump, but never again after this repair, it plugged up a small leak for one of my tires that kept going flat quickly and keeps the others from the eventual softness that was recurring.
Aug 23, 2009 | Maxi-Cosi Baby Gear
I have a Kenmore dishwasher that will not pump water through the spray arms. It fills ok and drains fine but wont go into the wash cycle? Any idea of possible problems
Look inside of the dishwasher to be sure that the tubes leading to the spray arms are not disconnected. If those tubes are in place, then the problem is with the main motor/pump in the base of the unit. That Kenmore part is about $150.00 plus labor. That being said, it may be time to consider a new dishwasher UNLESS your dishwasher is less than five years old because there is a five year warranty on the motor/pump. If it is under warranty, call sears repair and they should repair it at no cost to you.
Apr 18, 2009 | Kenmore 15762 Dishwasher
Problem with tires ,air is escaping
Pick up a kit for bicycle repair. Take the wheel off, deflate, pull the wheel from the rim and remove the tube. Pump the tube up a little, place under water and look for the bubbles. Once you find the bubbles, patch with the bike tire repair kit, deflate, put the tube back in, reattach tire to rim and inflate.
Apr 10, 2009 | Bertini Baby Gear
Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Oct 22, 2008 | Irons
Putting air in Bugaboo tires
You may also have a puncture.
The tyre and inner tube can be removed in the same way as a standard bicycle tyre, you can google how to remove a tyre to get some more advise.
Once you have removed the inner tube, place it in a bowl of water and try to inflate it with the pump. If you see any bubbles escaping from the tube, you have a puncture and will need to repair, again, additional advise can be found online or talk with your local bike shop for direct advise on how to do this.
If you see no bubbles you need to check that air is not escaping from the pump, if its broken then it will just vent the air as soon as you put it in.
Hope that helps
Simon
Nov 01, 2007 | Phil & Teds E3 Jogger
Airstrike Bell  1800 Floor Bike Pump Logo
398 people viewed this question
Top Airstrike Cycling Experts
John Egan
John Egan
Are you an Airstrike Cycling Expert? Answer questions, earn points and help others
