Question about Canon P1-DHV Calculator
Somehow I have pushed a button I wasn't supposed to. When I turn the calculator on there is an 'M' on the screen. I cannot remove it. This makes my totals show up with out the cents column.
  • Canon Master
  • 6,771 Answers
There is a couple things we can try, press the clear button on the calculator, failing that! remove the batteries for at least 60 seconds to see if it will clear "M stands for memory" the only other thing you can do is locate the M key, press once engages the memory, press again turns it off on some models.
Posted on Mar 13, 2011
I dropped my TI-nspire cx calculator in my sink for a few seconds, the screen still works but says "system error" how do i fix it
That is asking too much. The calculator is not supposed to take a bath no matter how short. Try to have it repaired, if at all, but do not expect that to be free of charge.
May 17, 2014 | Texas Instruments Office Equipment &...
Nothing shows up on the screen when I push any buttons. It will turn on, but after that nothing I push shows up on the screen. I have taken the batteries and the back up battery out.
Does the cursor show up at all? TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 29, 2013 | Texas Instruments TI-84 Plus Silver...
Sharp el 9300c
I took the EL-9300 apart to look for cold solder joints on the battery terminals. Found no bad connections. Make sure you remove all retaining screws.
Cleaned the pc board under the reset button. Cleaned the board under the slide switch that is actuated by the metal battery hold down clip. When you go to turn on the calculator install the hold down clip because it makes a connection to the pc board.
When I pushed the "On" button I got a down arrow. Push the "Reset" button when you get the down arrow. Various menus came up and I managed to reset the calculator.
Jun 06, 2013 | Office Equipment & Supplies
My touch screen is not working. after a long time
if you kept the batteris inside for long time it could be that they leaked inside when it happend there is some damage inside.
update for the OS sometimes helps
i fix this calculators
ecrdn@yahoo.com
Sep 25, 2010 | Casio ClassPad 300 Calculator
Screen is flashing 0.00
I had the same problem with my HP 11C. The following solution worked for me.
1. Remove the battery cover.
2. With the batteries in place (i.e. DO NO REMOVE THEM), use a small piece of wire (I used a standard staple bent at one end), short the terminals FOR A BRIEF MOMENT between both ends of the set of batteries (the HP-11C has three). This means somehow inserting the staple such that the contacts in the batteries receptacle are shorted.
3. The flashing will stop. Then push the ON button until the calculator turns on. If it does not work the first time, remove the batteries and resinsert them.
4. You may have to repeat this procedure. I had to do it twice before my calculator worked again.
Apr 28, 2009 | HP 12c Calculator
Screen fully black
Black-Screen/Black-Pixel Fix for TI-Calculator
This will erase all memory and reset defaults.
1. Remove 1 AAA Battery
2. Press and Hold 'ON' for 30 seconds
3. Replace AAA Battery
4. Adjust Contrast to appropriate level
If this fails, try again with ALL Batteries removed including
the backup Lithium Battery.
If all else fails, try the following reset procedure:
1. Remove ALL Batteries (inc. Backup)
2. Let Calculator sit with no batteries for 2~4 hours.
3. Hold 'ON' for 30 seconds.
4. Replace all the batteries (May be good idea to use new batteries
just in case old ones were dead)
5. Turn on Calculator
6. Change Contrast to appropriate level
- Remember to use correct batteries or calculator may not work. The
correct batteries are Alkaline, Rechargable Batteries are TOO WEAK,
Heavy Duty batteries are TOO STRONG.
Oct 09, 2008 | Texas Instruments TI-89 Calculator
TI 84 Plus Silver Edition
I actually fixed mine!!!! Mine was acting up too. I found somewhere that the no/slow key response could be due to a short in the I/O socket. I blew into it really hard (you may want to use compressed air, but I didn't have any onhand), and it works perfectly now!!!!!!!!!! I hope this helps.
Aug 27, 2008 | Texas Instruments TI-84 Plus Calculator
Casio FX-9750G Plus won't turn on
I had the same problem too. I just bought it and I was trying to turn it on but it wouldn't though the manual said that it was supposed to automatically when the tab was pulled out. Good news: the Reset button on the back works. I pushed it for some time with the end of a toothpick and it worked.
hope it helps.
Jun 17, 2008 | Casio FX-9750GPlus Calculator
TI-83 Plus Problem
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 29, 2008 | Texas Instruments TI-83 Plus Calculator
TI 84 Won't turn back on
Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL, reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Jan 11, 2008 | Texas Instruments TI-84 Plus Silver...
Canon P1-DHV Calculator Logo
148 people viewed this question
old marine
old marine
