Question about Epson Stylus CX4600 All-In-One InkJet Printer
Epson CX5400 Doesn't turn on.  Nothing Happens.   Moved plug to different outlet.  Still dead.
  • SpruceHead Oct 05, 2008
    Thanks for the solution.  I have gotten rid of the epson and bought a new printer.  That's the modern way, shame on me.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is the adaptor getting any power to it?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Change your printer adaptor & make sure that the input & output voltages & the current ratting are of the same value as the before.thanks.
Posted on Oct 05, 2008
I have a 922 printer and it won't turn on.
Did you try plugging the printer into a known live outlet? If the outlet tests good and has available power, check and make sure that no panels have come loose and could have tripped a safety switch during your move of the printer which could cause a no power up issue to prevent damage to printer. If still no luck, try a different power cord and se if that works. Hope this helps.
Mar 10, 2014 | Dell 922 All-In-One InkJet Printer
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
Epson stylus c62 went bang!
Well wish I had good news. Sounds like you're voltage distribution board got fried. BUT before we pronounce it dead, are you getting any codes at all? Or is everything blank? If your getting nothing, nothing you can do. Did you plug into wall or power strip? For grins, try one more outlet.
Oct 24, 2012 | Epson Stylus C62 InkJet Printer
When I plug in my pro form 370e crosswalk it doesn't turn on nothing happens
1) test the outlet wall, reset the c.breaker from your house, or tes the fuse if are blown.
if the problem NOT result and is o.k the c.breaker
2) test the power cord, for open
3) Eliminate any extension cord
4) test the main switch for open
5) reset the switch attached to the main switch.
6) tight any wires loose
7) reset the c. breaker or replace the fuse blown see the block.
God bless you
Jul 02, 2012 | Exercise & Fitness
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
We moved our TV from it's normal spot (hooked into different power source and cable outlet) and now it's dead. It won't turn on at all. We moved it back to it's old spot and still no luck. We bought it...
If it was plugged in during a power surge without a surge protector, there is a possibility it could be dead. Or if it was plugged into a new outlet without a surge protector, especially if it was never properly shut off before the move, that could kill it. Try unplugging everything and letting it sit for 30 seconds, then try again (with a surge protector if you have one)
Oct 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Nothing happens when i hit the scan button on my epson cx5400
you need the proper driver for the scanner which is compatible with your operating system.
what is the full version of your operating system?
You can download the twain driver off the support.epson.com site.
if you need more assistance please let me know.
May 12, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
59 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
