Question about Hampton Bay Heating & Cooling
Blown capacitor on a AC-5540d - Hampton Bay Heating & Cooling
2 Suggested Answers
  • 691 Answers
SOURCE: blown capacitor on 4 year old ac hampton bay is
Not common, keep in mind compositor work almost like a fuse but restrict certain amount of voltage to flow through, power surge or unit overload from AC compressor kicking on and off can cause the resistor to fail; its parts of electronics working. My AC unit trip my main fuse box once in the great while, nothing surprises me when it come to electronics.
Posted on Jul 16, 2009
My ac fuse keep blowing in my 2001 cavalier
something puling to many amps. might be bad capacitor.
Sep 02, 2014 | GE 60 Amp 240-Volt Non-Fuse AC Disconnect...
HPS6373x/XAA Power issue
Needless to say, it's probably not a blown capacitor. If the unit will not power on at all (control/standby indicators are not lit) the problem may be as simple as a blown fuse on your SMPS (near the AC socket) or on your Main Logic PCB. You should also use your fluke/voltmeter to verify that the Vs, Va, Vsc, and Ve values are reasonably close to those specified on the panel label. Re-post your findings!
Dec 16, 2013 | Samsung HP-S6373 63 in. Plasma Television
Was running ac. Now blower won't come on for ac or heat. Error code 24 is displayed. Please advise. Would a blown fuse at ac unit cause blower to stop all together
It could be your capacitor. I had a fan capacitor go out on one of my 3 units last year and it cost close to $300 for an AC company to come out and fix it. I watched them fix it and it's something that you can do yourself if you know what you're doing and are careful to hook it up right. I have three AC units and another capacitor went out this year and I found a kit with detailed instructions with pictures and phone support at hvacrepairkits.com. It saved me over $200 on the capacitor replacement.
Aug 14, 2011 | Carrier 38CKC036 Air Conditioner
My ac blows nuetral air and the compressor does'nt come on when the car is started.
90% of the time with car and home air conditioners it is the capacitor that has blown. They are usually pretty cheap and in most cases easy to get to.
You may be able to find a step by step repair guide on the net. Locate the capacitor and remove it, but first remember or write down the wire locations first.
Once removed most all capacitors are flat on top and bottom and by design when they go bad they blow outwards like a dropped coke can. it will have a concave or bowing outwawd on one or both top and bottom. Also most ac repair shops will test it for free.
In my home I saved $180 - $350 changing it myself. The capacitor was only $50
L8ers
Sep 12, 2010 | 2001 Volkswagen Jetta TDI
ASUS Eee PC running Ubuntu will not boot after pressing the power button. I have already taken the battery out, tried ac power only, pressed the reset button, and checked the RAM. The indicator lights are...
Hi! Please check the motherboard for blown or corroded capacitors. If the capacitors are faulty it can result to a sudden reset or no boot at all. YOu can determine a blown capacitor if it has a whitish powder on the top or theres a leak on the top. Once replaced you'll be good. Hope this helps and have a good one!
Jun 02, 2010 | ASUS Eee PC 900 PC Notebook
Blown capacitor on 4 year old ac hampton bay is
Jul 16, 2009 | Hampton Bay Heating & Cooling
Kemore ac model 75151 compressor wont come on any ideas
If you're main power is 115v and the capacitor is rated 220v it could work. But if the other way around the capacitor would melt or blown if use.
May 25, 2009 | Kenmore 75085 Air Conditioner
Why my ac is on but its not cold
Check the condensing unit (the outdoor section). There are two motors in this unit, a fan and a compressor. If both are not running then you may have a blown fuse or circuit breaker. Fuses are sometimes located in the disconnect box next to the condensor. The circuit breaker is located in your main breaker box. If only one motor is running or neither is running but there are no blown fuses or breakers then you probably have a bad start capacitor. This capacitor should be replaced by a someone knowledgeable in residential 220VAC equipment.
Jan 13, 2009 | Heating & Cooling
Dell - nps-200pb-73M not working
dont know the AC and the DC of my NPS-200PB-73M
Apr 25, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Not working
Good day.
Have you checked on the AC line of your washing machine?
Maybe the starting capacitor has blown off or the fuse from the ac line to the micro computer is busted. Please check
Mar 11, 2008 | Washing Machines
Heating & Cooling Logo
123 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
