Question about LG WM1812C Front Load Washer
LG Washer 1812CW makes a lot of noise when it's draining why?
  • 52 Answers
SOURCE: washer won't drain. Makes grinding noise
check your water pump. there maybe something in it. If there is you may have to replace the pump
Posted on Nov 06, 2009
maintenacemi
  • 95 Answers
SOURCE: LG WM0642H front load washer making a loud vibration-type noise
mc not level
Posted on Nov 18, 2009
  • 10865 Answers
SOURCE: Need to buy drain pump for LG washer WM1812CW but
Hello. you can order the LG parts from any home depot.
Posted on Mar 08, 2010
heatman101
  • 43501 Answers
SOURCE: my LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 17, 2010
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Posted on Aug 03, 2010
My LG Wahining machine is making a rattling noise and will not spin or drain.
For the washer to spin, it must first drain the water out of the tub. Since you are hearing a rattling noise, and your washer will not drain, most likely the problem is the drain motor itself. The impeller wears out on the shaft, and start to wobble, and make a vibrating/rattling noise.
Sep 23, 2014 | LG WM2487H Front Load Washer
My lg washing machine is making a lot of noise when it is spinning and it wont spin out the water to good
Hi blare131,
I believe there may be a foreign object in you drain pump filter, this must be removed (Should solve both issues)
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 17, 2011 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
Lg-wm1832cw front loader washer won't spin and drain
Apr 12, 2010 | LG WM-1832C Front Load Washer
Makes Noise When Draining on Spin
could be coin in pump..Check this
Apr 08, 2010 | LG WM2487H Front Load Washer
either drain pump itself is broken or something jammed in between the pump housing and pump impellor. the drain hose itself or pump cleanout cup (behind lower left access panel) may be clogged too.
Mar 26, 2010 | LG WM-2277HW Front Load Washer
Washer won't rinse and spin
clean the drain hose, but make sure you have a container to catch the water and lot of debris will come out. Then unplug the washer and put water on spin cycle to drain water, after draining water remove the pump filter located next to the drain hose turn left to open and clean more debris. I found my husband wedding band I thought he lost it on purpose. You will be surprise how much funk is in that filter. Turn pump filter to right to close and put cap back on hose. Don't call the repair guy. Hope this helped.
Darlene, New Orleans
504-296-4391
Jul 24, 2008 | LG WM-1832C Front Load Washer
Lg wm1832cw front load washer
One of 2 things may be causing the loud noise.  Either the rear bearing on the drum has failed and will need to be replaced (very expensive) or the drain pump has a bearing problem and is making a very loud noise when it is draining (not too expensive).  Either way, you will need a qualified LG technician to diagnose and repair the problem.
Jun 14, 2008 | LG WM-1832C Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG WM1812C Front Load Washer Logo
65 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
