Question about Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop
Gateway profile 4 computer turns on but then shows that there is no hard drive connected, do I take off the back and look for anything that looks like its disconnected? I am on a different computer right now because the profile 4 wont do anything after it shows that its not regestering a hard drive.
    Master:
  • 525 Answers
Yes. You will need to open up your case and check if the hard drive is properly connected. If it is, then you may have a dead hard drive.
Posted on Mar 14, 2011
When i turn on the latop it says gateway and also says repairing pc and it wont go any further
try turning on your laptop in safe mode with command prompt by hitting f8 on startup,
try to check your your hard drive on typing "chkdsk" command. it will show the status of your hard drive. if it doesnt work theres problem with your hard drive
Apr 27, 2016 | Gateway Computers & Internet
I have A gateway dx4870 ub308. when i turn it on it beeps 4 times and even tbought the on light stays . on it won't do anything else
The hard drive or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Jun 19, 2014 | Gateway DX4870 Desktop DX4870-UM20P
Check cable connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key
Hard drive is not detected. Change the Boot sequence in BIOS
1. To access the BIOS you must tap F2 or delete key upon turning the computer on
2. Try to look for the Hard drive if it is detected by BIOS if not got to step 6
3. Look for Boot Sequence or anything that is associated Boot
4. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
5. Save the changes and Restart
6. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
7. If Step 6 did not work I think you need to replace the Hard drive
Thanks for Choosing
Jun 16, 2011 | Acer Computers & Internet
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Nov 12, 2017 | Gateway MX6428 Notebook
Trying to change out power supply on a Gateway DX4822-01. Can hear hard drive spinning, but not getting anything on screen. Unplugged it yesterday. Now wondering if one of the 4-pin needs top be...
Trying the easiest solution first - It sounds as if the power is getting to the hard drive, but the information is not getting to the computer.
Is the IDE/SATA cable attached to the hard drive AND the motherboard?
Are the connections tight?
Is one end of the cable reversed - does pin 1 on the hard drive correspond to pin 1 on the motherboard?
Are the jumper settings on the hard drive set properly - Master/Slave/Cable select?
Are you replacing an IDE hard drive (uses a wide thin ribbon cable) with a SATA drive (uses a narrow, fatter cable). Can your motherboard handle a SATA drive? Perhaps you are trying to install the incorrect hard drive?
Dec 24, 2010 | Gateway GT5220 PC Desktop
Gateway Profile 4 with two hard drive failures
How do you know 2 hard drives have failed, have the hard drives been fin in another computer.
most likely the OS is corrupt on the disks caused my another hardware issue, most likey Motherboard IDE/sata controller.
Sep 06, 2009 | Gateway Profile 4 All In One (MPN...
Computer will not boot
Does your pc make a different noise than usual when you turn it on? If it sounds like clicking (loud) then your hard drive has crashed. You will need to replace it.
May 28, 2009 | Gateway Profile 4 All In One (MPN...
Profile 4
Download some free hard drive testing software, like seagate tools,from:  Seagate.com  or another had drive manufactor. They run from a disk w/o windows . If the hard drive checks out try reinstalling the system. Another quick test , for conformation is to hook up you monitor to anther computer just to make sure it is not the monitor. It rarely is.
Mar 01, 2009 | Gateway Profile 4 All In One (MPN...
MY GATEWAY PROFILE 4 ISSUES A PROBLEM WITH THE HARD DRIVE.
Bad news. Your hard drive has had a SMART failure and subsequently crashed. If your data was important, I would get the computer to a skilled professional as soon as possible. Ideally, you can get them to make an image of your drive. That will get you back to right before the crash. If they can't do that, there are data recovery places like gillware.com that can help you out for a flat fee.
Jan 25, 2009 | Gateway Profile 4M PC Desktop
Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop Logo
108 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
