Question about xheli 9053 Outdoor Volitation Metal Helicopter
I pushed the trim all the way forward on the remote but the heli takes off going backwards every time
    President:
  • 1,961 Answers
Hi ,
the problem is not on the trim its the forward backward button make sure that the blades on the tails engaged when you pushed the forward button check the blade if it is not broken or is spinning to its full speed replace the motor.good luck!
Posted on Mar 13, 2011
  • kenkidd373
    kenkidd373 Jan 06, 2012
    Another way to deal with this problem. This helicopter is tail heavy by design. Remove the canopy. Loosen the battery bracket. Move the battery as far to the front as possible while still being able to plug it in. Tighten up the battery bracket. You can further enhance the forward movement of the helicopter by adding a small weight to the nose to increase the forward tilt of the copter. You will be airborne in no time.
My heli wants to fly foward as soon as it takes off. iv tryed allot of suggestions. whats my problem? cant cotrole it alt all.
you will have a trim button on the remote ? let it sit on the floor and before you try to take off click the trim button ...this should stabilize it
Apr 24, 2015 | Generic Night Hunter Xtreme...
Tip
Infrared RC Copters
Hi, everyone.
Ever since I saw the first advertisements on YouTube, some years ago, I wanted to acquire one of these little helis. When I finally acquired one, I had lots of fun until the little thing started to give me trouble.I own several of these mini-copters and have managed to maintan most of them in good working conditions for about 4 years now.
I would like to share some things that I have learned about RC Infrared Helis, specifically speaking, the airhogs RC helicopters.
First of all these little copters are not intended to be used outside home unless on a very calm day and on an area that has to be protected against sunlight, because sunrays interfere enormously with the IR beam with which the Infra-red light-emmiting controller communicates with the copter. I have found out that even while flying an air hogs copter indoors, when you get them close to a ray of sun shinning through a window, it suddenly drops to the ground.
Next, Most problems that I have encountered have to do with a combination of low battery power, plus trimming. In some of these copters, trimming can take a great deal of pulses before you can get them to fly right.
On the first models I would cut a cardboard fin and tape it to the front of the heli, below the nose and across form it, side to side to make it thrust forward.
Many times there were things like hairs or pieces of cobwebs attached to the axle of the back rotor, causing the heli to spin uncontrollably, even after trying to trimming it with the remote contol.
On other ocassions the copter wouldn't hold a charge even with fresh batteries on the controller. I learned that in time, the charger connector/plug may get dirty, so I usually spray the inner part of these connectors with a light coat of contact cleaner(available at any electronics store like Radio Shack) and then plug and unplug the connector a few times. This has worked fine with my older copters that have presented such problems.
on Sep 26, 2011 | Silverlit Toys Red Air Hogs R/C Havoc Heli...
My 9053 lifts off fine goes left right and reverse. but it goes reverse also when i want to go forward . Tail rotor turns at what appears proper rpm. and it changes direction when i push stick from reverse...
I own this heli also. The problem is that the tail rotor does not apply enough push to tilt the heli forward. It is this forward pitch that moves the heli forward. Aside form buying a stronger tail motor, upgrading your battery etc, the only thing you can do id this:
Get a credit card, a pair of scissors and some tape. Cut a couple of strips from the credit card about 2 1/2 - 3 times wider thhan the tail rotor blades and the same length. Now tape the strips to the top of the tail rotor blades. Make sure you don't increase the length.
This will help a little by providing more air push when the tail rotor in engaged. Without some serious modding, this heli will never be great.
I have more fun flying my micro size syma helicopter in the garage then I have flying my volitation. If there is even the slightest breeze, the volitation will float in the direction of the breeze and will not fly against it.
Apr 03, 2011 | xheli 9053 Outdoor Volitation Metal...
I have a s 107 and it will not go forward or backwards. everything else seems to work fine.
This has happened to two of mine, fairly common problem if you keep hitting things with your back rotor.
Solution 1: Replace the tail assembly
Solution 2: Remove the canopy and put a small weight in the nose which will serve to drag your heli forward. No backward flight but it works better than a heli that just hovers.
Mar 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
How do i fly my spin master air hog rc helicopter all it does is go in circles
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
I CAN'T QUITE TURN GOOD YET.
Keep hitting the right trim button till the turning stops.
May 16, 2009 | Air Hogs Havoc Heli Helicopters
My heli wont hover, takes a large spiral downward, always to left
You either need to charge the battery, or just keep tapping the r trim button.
Mar 06, 2009 | Air Hogs Havoc Heli Helicopters
Open Questions:
xheli 9053 Outdoor Volitation Metal Helicopter Logo
234 people viewed this question
Top xheli Toys Experts
MeAndMyBrain
Level 1 Expert
Tom Chichester
Rani wadia
Rani wadia
Are you a xheli Toy Expert? Answer questions, earn points and help others
