Question about HP Photosmart 2575 All-In-One InkJet Printer
My all in one printer says error 0x07674dd6 1895 lib_barracuda
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
Script: chrome://wrc/content/common/libs/jquery-1.5.2.js:3589
Script errors are common. The best thing to do is to go to the internet options and deselect the entry that says "warn me of script errors".
Though the errors will still be there you won't get the notice!
Jul 30, 2014 | Google Chrome
Linker error:Unable to open file 'TCLASSS.LIB'
this is the basic lib class required by the compiler make sure your libs variable to pointing to the correct location the the libraries required by the compiler.
Sep 25, 2012 | Borland Turbo C++ 3.0 Full Version...
What is an error 1-2070 mean?
Check to see if the required files are present:
  • Go to C:\WINDOWS\system32\kodak. Check for 2 folders "kds_aio5000(for AiO 5000 series printers) and kds_aioesp(for ESP series)
  • Depending on printer model, open kds_aio5000 or kds_aioesp.
    • For kds_espaio it should only have the lib folder. It doesn't have the ekaiowia.dll
  • Inside the lib folder it should have cct.ekpgct, hippo.dll. Both for kds_aio5000 and kds_aioesp.
  • If hippo.dll is missing then try the following:
Option 1: 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner 2. Right click on aioscnnr.msi2_bing.gif and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 2 Option 2: 1. Insert the Home AiO CD. Go to CD rom2_bing.gif drive\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 3 Option 3: (manual installation) 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner or on CDROM drive2_bing.gif ..\printer\scanner 2. Open the aioscnnr.cab file then look for the missing file(files needed: cct.ekpgct, hippo.dll, and ekaiowia.dll) Extract the files anywhere on to the computer (Desktop is preferable). 3. Copy the cct.ekpgct, and hippo.dll to C:\WINDOWS\system32\kodak\kds_aio5000\lib 4. Copy the ekaiowia.dll to C:\WINDOWS\system32\kodak\kds_aio5000
Apr 30, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
My samsung ml-1610 series printer's software is installed but the printer is not installed
my oj 7310 all in one is give me error mesege 0xc0620004 411:lib-micci2.c
Nov 03, 2009 | Samsung ML 1610 Laser Printer
I keep getting error 1-2070
Resolution
Option 1: 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 2 Option 2: 1. Insert the Home AiO CD. Go to CD rom drive\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 3 Option 3: (manual installation) 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner or on CDROM drive ..\printer\scanner 2. Open the aioscnnr.cab file then look for the missing file(files needed: cct.ekpgct, hippo.dll, and ekaiowia.dll) Extract the files anywhere on to the computer (Desktop is preferable). 3. Copy the cct.ekpgct, and hippo.dll to C:\WINDOWS\system32\kodak\kds_aio5000\lib 4. Copy the ekaiowia.dll to C:\WINDOWS\system32\kodak\kds_aio5000
Apr 12, 2009 | Kodak ESP 5 Printer
Error message
My printing stops and I get this error message Error-0x07a74dd6 1959:lib_barracu.
What is the meaning to this and how can I fix the problem?
Mar 17, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
54 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
