Question about Symphonic ST419E TV
I have a 1 in all four corners of my T.V. and a 189-0.19 thing in the center of the screen and can't use my remote to fix the issue
I have the same thing. All was fine until I hit the direct tv remotes mute button then immediately the volume went UP and the remote no longer worked for the TV. Amazing.
Posted on Jun 23, 2011
UNIVERSAL REMOTE CODE for SUPRA ST29K33F TV
Your question is very vague, but it sounds like the picture on the TV has faded away in the corners and probably looks like a circle in the center of the screen....? If so this has nothing to do with your remote control and everything to do with the TV . I would toss it and invest in a new flat screen. Don't waste money trying to repair TVs - they are now disposable items.
Jan 24, 2015 | Universal Televison & Video
Screen displays #1 in the center of the screen and 2,3,4,5 inthe four corners
it is calibration, hold your finger on the x until it moves to the next number.
Aug 12, 2012 | Jensen NAV104
Have numbers and letters on screen and wont go away, im able to see the picture but no sound sound from tv. these are the numbers that appeared on screen 058-0.06 271 A1 (top) 0F F6FD (bottom) and the...
U have the tv original remote wright?This problems likely parts of Close Caption problems.Look for a button that said CC on the remote press it make sure all like CC1,2,3.. to off should solved this problems.Or tries go into the main tv Menu looking for Close Captioning functions turn off to all CC1...and Text1... all to off.Will fixed this problems.
Jun 07, 2011 | Emerson EWF2004 20" TV
Put new batteries in the remotes and the four lights blink twice when you push power
You might have to resync the remote take off the battery cover and push the red button under there to resync it with your wii, you will have to do the same thing with a brand new remote or when taking the remote from one wii console to a friends.
If this isnt working then your remote batteries are bad or you are having a hardware issue with the remote. Unless your trying to play a game cube game this is another issue and has nothing to do with your wii remote working or not.
post back if this dont fix your issue
Apr 23, 2010 | Nintendo Wii Remote Controller
Convergence Problem
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
May 21, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Akai LCT42Z6TN
I had the exact same problem already and my LCD is less than 8mo old. One of the techs from AKAI told me that its a known problem and many tv's were coming back "unserviceable". They now have a "supposed" fix for the problem. I only hope it really works and its not just a "carry-over" until the warranty ends. I am beginning to think its a quality issue and the units may just be defective. Thismay be thier way of doing a quick-fix vs. recalling all those tv's. This is what he gave me to as a solution to give the serviceman when he comes to fix the LCD.
AKAI model LCT42Z6TM: If there is no image or a badly distorted image with horizontal static lines, usually with four boxes in all four corners of the screen, there is a possible fix for this. There are four capacitors on the main board that have been identified as the primary cause of this symptom. Replace the capacitors at location numbers C280, C302, C320, C323 - 100UF 35 VOLTS [dxh]
Dec 12, 2007 | Akai LCT4216 42 in. LCD Television
TV - Color Issues
unplug it and plug it back in. this should fix it
Sep 23, 2007 | Toshiba MV13P2 13 in. TV/VCR Combo
Touch screen calibration
Touch screen not working for sony ericsson P990i Mobile phone
When I hit the center some part above gets highlighted and selected and the botton part where the taskmanager and battery icons are present does not respond to my taps ... what could be the problem,,, kindly help me solve the issue.
Praveen
Aug 24, 2007 | Sony Ericsson P990i Cellular Phone
HELP
There is not much you can really do to rectify a screen problem, but there are four little black blanks in the corners of the screen,remove and see if any tightening or loosening of the screws alter it. Caution applies as the wireless receiver is built in the screen and can get damaged and that may also be causing the interference.
Mar 17, 2007 | Acer Aspire 3000 Notebook
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Symphonic ST419E TV Logo
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
