Question about Dell Latitude Inspiron Modular Bay 24X CD Dell Part Number 5044D CDROM Drive
Cd rom light is not on as well will not open - Dell Latitude Inspiron Modular Bay 24X CD Dell Part Number 5044D CDROM Drive
  • 2,574 Answers
First try rebooting the system since it is possible the controller or power connection may have failed.
If the CD-ROM drive failed after rebooting, remove the system unit cover after unplugging the PC and disconnecting all peripherals. Locate the CDROM drive, disconnect the power connector. Check for power by connecting the spare connector to the drive.
If the drive works, the connector is faulty. If the drive does not work, use a multimeter to check for power to the drive. If the drive does not work and there is power from the power supply, the drive is bad and should be replaced. If the multimeter reveals no power at the connector, use the spare connector and realize that the power supply is slowly going bad.
Posted on Mar 13, 2011
I have a notebook 4520G and a couple of days ago after finally sorting out the problems with the graphics card I now find that the drive for the CD rom has totally disappeared. When I inset a disc the...
Hello there is no problem with the driver of your CD rom the problem is in your CD rom. Try to clean your cd rom with a piece of clean cotton. Gentle rub the cotton on the lens of your CD rom, then try to insert a cd if the problem is still there clean it again and again. If does not get by cleaning it is good to be checked by a electronic technician because maybe the lens have a problem or may need an adjustment to the lens of your CD ROm. In ejecting your cd rom there is a problem with your cd rom microswitch which is located inside your CD rom or the trigger of the microswitch is miss align. Hope this can help..
Jul 17, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Hi my cd rom will not read a disc or pop out when I press the button and the light will not come on
to open the cd rom u will need a small pin, there is a small hole on the front panel of the cd rom drive, insert the pin into this hole and the cd-rom drive should pop out...oh and i think you will need to replace the cd-rom drive because its had its best days!
Jul 09, 2010 | Compaq Presario Notebook
Cd brokes in cd rom
IS IT ON?...DOES CDROM HAVE POWER GETTING TO IT FROM PC? Next to open/close switch there is a small pin-hole. Push a paperclip into this hole and gently pull out tray...try gently pushing tray back in and watch for a blinking green light;if none either the cdrom is not getting power, or it has quit working
Mar 20, 2010 | E-Machines emachines (emachinees) CD-ROM...
Cd rom not working
why???
is the cable is properly installed??/
check the cables red meets red..
is the led of the cd rom lights..???
if it lights..
try to click open when it opens the problem is your IDE or SATA cable..try another cable if it is still not working...
you cd rom is damaged..hope it helps
Feb 06, 2010 | Intel D945GCL Motherboard
My cd-rom will not open my computer is saying the drive is not there
is their any light from the CD-ROM power led when you try to open it.....if not try to check power connection inside the case
Oct 26, 2009 | Computers & Internet
CD-ROM not opening
The eject mechanism is driven by a seperate belt. You'r's is worn or broken, however, there is a small pinhole in the face of the player that you may stick a paperclip into and the tray will open.
Oct 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Computer doesn't recognize CD-ROM
Click on the link below and click on the "Fixit" button. It's a registry patch from Microsoft for unrecognized CD/DVD devices. Best of luck.
Greg
http://support.microsoft.com/default.aspx?scid=kb;en-us;314060
Jun 10, 2009 | Computers & Internet
When I press the bottin on the dvd burner to open the door, the green light comes on and i would hear the door try to open but no open.
yes frn this is happen due to the jam in the DVD rom. when you press the eject button put one pin in the hole that is just below the eject button. so that you can eject your DVD. or just hit the cd ROM slowly.
May 16, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Dell Latitude Inspiron Modular Bay 24X CD Dell Part Number 5044D CDROM Drive Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
