Question about Omega 1000 Juice Extractor
My lid doesn't seem to fit properly. When I put the top on to cover the screen, it doesn't seem to fit together properly-- the bottom of the chute that you throw the fruit and veggies down butts right up against the blade, not allowing it to spin. Is there a possibility the wrong lid was put on this model? are there lids with shorter chutes? am i missing something obvious? please help!! thank you!! Mine is the seemingly older model w/ the blue lable and stainless steel top.
    Champion:
  • 356 Answers
Is this a new cover? There is an adjustment. On the bottom of the machine, dead center,
there is an adjustment screw with a locking nut. Unlock the nut and the turn the screw
counter clockwise, this will lower the motor shaft and consequently the blade. Once you
have clearance and install the cover, turn the screw clockwise until the blade contacts the
chute, back it off a half turn and lock her down. This will establish the correct gap between
the chute and blade. Also if your chute is ever chipped or scored by the blade because
of excessive vibration, you can file the chute level and readjust the gap.
Posted on May 02, 2011
Testimonial: "Thank you so much for the valuable info!"
Opening lid to add fruits
The Manual for the Acme 5001 Supreme Juicerator can be downloaded from the following link:
http://www.everythingkitchens.com/PDFfiles/6001.pdf
Items to be juiced must be cut to size and fed through the feed chute. The machine will not operate if the cover is not properly in place.
Jul 23, 2012 | Acme 5001 Supreme Juicerator Juice...
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Mar 07, 2012 | Champion G5NG853S 540 Watts Juicer
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
Hi I have an older acme supreme juicerator, model # 11je23. Do the newer baskets & lids fit this older model? Or can a guy get original parts?
Believe the basket is the same. The newer lids have a flange
around them which can be filed down. Takes time, but file away
tapering it until it fits in the juice bowl. With a new lid you may
have to adjust the chute to blade gap. On bottom loosen center
locking nut and turn adjusting screw clockwise until chute contacts
blade, then back it off a half turn and lock it down. A few older lids
are around, but it's hit and miss.
Nov 05, 2010 | Acme 6001 Juice Extractor
The 6001 vabrated so much the top came off and the flang bent.
WARING AT 800 492 7464 HANDLES ACME
JUICERS. VIBRATION MAY NOT INDICATE
REPAIR. THIS JUICER DOES NOT EJECT
PULP SO IS PRONE TO VIBRATION JUST
LIKE AN INCORRECTLY LOADED WASHING
MACHINE. HOWEVER, SEVERE VIBRATION
WILL CAUSE THE BLADE TO CHEW UP THE
CHUTE. YOU WILL NEED A NEW COVER.
TALK TO WARING. ANOTHER PROBLEM
IS NEW COVER PROVIDED WILL NOT FIT
SOME OLDER JUICERS WITHOUT FILING
DOWN THE EDGE OF THE COVER. TAKES
TIME BUT CAN BE DONE.
Jun 24, 2009 | Acme 5001 Supreme Juicerator Juice...
Heavy vibration and noise
YOU MAY HAVE CUT THE COVER CHUTE
INCREASING THE GAP BETWEEN THE
BLADE AND CHUTE BOTTOM ALLOWING
LARGER CHUNKS TO PASS THRU. INSPECT
AND IF NEEDED ORDER NEW ONE FROM
OMEGA AT 717 561 1105. ABOUT $15.
Dec 28, 2008 | Omega 1000 Juice Extractor
Vibration
DIFFICULT TO USE. SHOULD HAVE GONE
FOR THE 4000 WHICH EJECTS THE PULP.
SOMETIMES THE BLADE JUMPS UP AND
CUTS THE BOTTOM OF THE CHUTE IN-
CREASING THE GAP BETWEEN THE BLADE
AND CHUTE BOTTOM. INSPECT AND I YOU
NEED A NEW COVER CALL OMEGA AT 717
561 1105.
Oct 01, 2008 | Omega 1000 Juice Extractor
I need the cover lid
CALL WARING AT 800 492 7464 OR COST
PLUS JUICERS AT 800 578 5939. WHEN
THE JUICER VIBRATES BADLY THE BLADE
JUMPS UP AND CUTS OR CHIPS THE
CHUTE.
Jul 01, 2008 | Acme 5001 Supreme Juicerator Juice...
Omega 1000 Juice Extractor Logo
109 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
