Fitting a solenoid
I need a new Soleniod for my Bosch WF 1200. I can see the 3 wires run around the inside of the machine and end up just behind the start button. What do I need to do to 'plug them in'
I also assume the Solenoid just twists off ? No special seals required
    Genius:
  • 1,028 Answers
Sorry bosch is not 1 of my regulars ..just strated working on a few and not familar enough yet to give information i'm not sure of..but thanks for the confidence
Posted on Aug 06, 2008
How to replace brushes on a classic 6 1200
Disconnect the power
disconnect hoses
lay machine on it's left side
remove back cover screw and cover
slip belt off pully
unplug motor wires
undo bolts holding motor
pull motor to rear of machine
revome motor to bench
locate brush housings
undo retaining clip and slide out old brush
fit new brush
replete with other brush
reasonable in reverse of removal
Oct 04, 2014 | Bosch Washing Machines
I need a picture of the wiring connection on an LG washing machine.WF-T755th please
there is only 2 wires on solenoid valves it doesnt matter which way they go ie. 1live 1neutral
May 09, 2014 | LG WFT1071TP Top Load Washer
2001 Volvo s80 torque converter clutch soleniod
DTC P0740: Torque Converter Clutch Solenoid Circuit / Open
Probable cause:
  1. Sensor or solenoid faulty
  2. Connector terminal contact damaged or corroded
  3. Wire harness fault. Check for correct voltage, open, short to ground or short to voltage
  4. Update control unit software
  5. PCM or ECM defective
Jun 25, 2017 | 2001 Volvo S80
Front seal leaking in my bosch exxcel 1200
This video will show you how to change a door seal on this bosch bosch exxcel 1200
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Bosch Classixx 1400 Express does not start at all, does not fill.
fit new door interlock switch ..Take note of wiring 1st//
Oct 04, 2009 | Washing Machines
PROBLEMS WHITH THE TRANSMISSION CONTROL SOLENIOD
===shift interlock solenoid--Inside the steering column near the ignition switch
===1-2 shift solenoid valve--Inside the automatic transaxle
to remove it :
  1. Remove the case side cover. Refer to Case Side Cover Replacement.
  2. Disconnect the transaxle wiring harness.
  3. Remove the 1-2 shift solenoid (315A).
2-3 shift solenoid valve--Inside the automatic transaxle
to remove it;
  3. Remove the 2-3 shift solenoid (315B).
==the torque converter solenoid--inside tranny too
good luck,let me know
Jun 04, 2009 | 2000 Pontiac Montana
How to change door seal on hotpoint m w a 60 washing m/c
you need to remove the outer retaining ring which is a wire around the lip of the seal typically joined with a spring., using a small screwdriver.
the inner retainer is held together by a ratchet type assembly. prise one end of the wire by twisting the folded end of the wire out of the groove til it comes free.
replace the seal. fit the inner retainer together using some long nose pliers, prefferably bent-nosed. the outer retainer with a screwdriver.
Feb 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
The drum won,t go around or spin BOSCH Classixx 1200 washing machine
BOSH WFL 2260 SPINS OK BUT WASHING CYCLES DO NOT WORK. FILLS WATER OK
Sep 26, 2008 | Bosch Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
