SOURCE: VGA Adaptor to HMDI Connector
you have to right click on an empty space on your desktop and choose either graphics options or graphic properties and select the external monitor, it depends on the graphics chip fitted but they are all similair
SOURCE: Toshiba 40XV645U - No picture on HDMI 1 when TV is turned on
I have the same issue with a Toshiba 46XV648U. I talked to Toshiba customer service and the individual I spoke with was not aware of this problem, but they are sending me a firmware update for the TV that "might" fix this.
SOURCE: hello, I have LC-42D65U, the
It may be in the safety shutdown mode due to fault in the circuits. Need to do some voltages checking.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
SOURCE: WE have am AQUOS LC
Unplug it for about an hour to see if it will reset itself, if not, you will have to do some in-depth troubleshooting or have it repaired.
First two board to check will be the power supply module and the backlight inverter board. You will be looking for bad caps, cold solder joints, short circuits in the power supply and in the inverter board.
Please read my guide so you get some basic understanding on how LCD TV works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
SOURCE: Need user manual for 42"sharp aquos lcd tv
Hello
Get into this link. You can download the user manual for your device absolutely free.
www.retrevo.com > Sharp Manuals > Sharp TV Manuals
OK.
