Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
Controller has 8 flashing lights - Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
    Guru:
  • 811 Answers
After researching this question for you I came up with a charging issue when the lights keep flashing. This means that battery is either bad or came loose or the charger on board went bad and will not complete the charge my best advice to you is to take it in to a local shop to have it serviced. Thanks for using FixYa! John
Posted on Mar 13, 2011
I activated the cruise control on my 95 Nissan Sentra and now it won't disengage...any suggestions?
Cruise Control Problem - Nissan Forum
www.nissanforums.com/b13-91.../135028-cruise-control-problem.html
Jun 21, 2007 - 4 posts - ‎3 authors 1994 Nissan Sentra 4Door XE with 5 Speed Manual, GA16DE, 230k Miles. ... Now theCruise control light in the middle of the dash will NOT light up and the cruise control will not engage no matter what button I push. .... Cruise Control NOT working.. sentravis, B14 95-99 chassis, 26, May 29th, 2009 12:24 ... speedometer not working?
Aug 3, 2007
Solution for P0500 VSS speed sensor problem on Nissan ...
Jul 10, 2007
Solved flashing cruise control light
Sep 8, 2006
cruise control problem
Jul 13, 2005
More results from www.nissanforums.com
Sep 30, 2015 | Nissan Cars & Trucks
Was working ok but washed it now it just flashes a red light 8 times and wont go along
8 flash code is typically a controller fault and there are about 12 sub codes that goes along with that flash code. More than likely you will have to replace the controller.
Sep 05, 2014 | Golden Technologies Liteway 3/4 Wheel...
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Westek SLC6CFL programming instructions
Copy following link for Westek outdoor socket timer instructions:
http://waterheatertimer.org/pdf/Westek-SLC6CFL-timer-instructions.pdf
Jun 27, 2012 | Ace Hardware AMERICAN TACK 3236858...
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
I bought a rascal fold and go 370 for my sister because she needs it really bad and I have checked all the wire conections and the battery charger is still at red but has been on for about 8 hours the...
Flashing lights will dinicate what the problem is by the number of bars that are flashing. Here is a website that may help you, if you no longer have the owner's manual. Locate the controller that is on your scooter to dtermine what the blinking lights mean and if the problem can be serviced by you.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Oct 19, 2010 | Health & Beauty
Flashing airbag light on 97 maxima. Car was in an accident, airbags deployed, replaced bags and controller why won't the light stay off
To manually check air bag codes, turn the key On and push the driver's door switch (at the bottom of the B-pillar) 5 times or more within 7 seconds of turning the key ON. Then watch the air bag light flashing codes. The air bag light will come ON for 3 seconds and then give fast flashes if there is a code. Count the fast flashes as the code. So the air bag light on for 3 seconds and then 8 flashes is a code 8 for the passenger air bag circuit. after counting code clear codes and see if they come back
Nov 22, 2009 | 1997 Nissan Maxima
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Problem with my 61 inch LIFI
I had the same problem, turned out to be the bulb, had it replaced and now I`m having problems with the new bulb (dark picture).By the way the first bulb lasted only 8 months and it has been 8 months since the new one was put in, so much for the 5 year bulb.
Mar 27, 2009 | Motorola Mobility DRC800 Universal Remote...
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
187 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
