Question about Janome Sewing Machines
The bobbin holder is not rotating to allow needl to come down and pick up the bobbin thread. I have tried cleaning lent out and don't know what else to try. Help.
  • Janome Master
  • 1,564 Answers
Hello:
Remove the bobbin holder and check underneath for foreign materials. Then replace ensuring it is replaced correctly. Your manual should have a diagram which shows how it should sit. Test by using the hand wheel.
Double check that your needle isn't bent.
Posted on Mar 14, 2011
How do I engage the boobin to the top thread?
wind thread onto the bobbin
place the bobbin into the carrier pulling the thread around the edge until it goes down the slot and under a flat spring
pull about 6" of thread out
put the holder into the machine
hold the needle thread and turn the machine by hand
in 2 or 3 full rotations the needle thread will have picked up the bobbin thread and you can pull both threads out ready to sew
if it is not happening , take it in for a service as the needle /hook timing may be out
Jun 12, 2016 | Sewing Machines
The needle is not picking up the lower thread, I have cleaned the machine but the bobbin is not being picked up
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Feb 10, 2016 | Sewing Machines
Problem with thread getting caught under bobbin holder
have you applied any lubricant to the bobbin holder the one that holds the bobbin? I would suggest using your manual and lube your machine. sounds to me like your mechanism is sticking.
Jun 08, 2015 | Janome Sewist 625e
I can't seem to get the bobbin holder in there correctly to get the machine to sew properly.
While I know it can only go in 1 of two ways, maybe the problem isn't in how the bobbin is in, maybe it is the route of the thread.
My assumption is you don't seem to pick up the bobbin thread and it bunches. If so the carefully follow the thread to needle you may have by passed the place you put that thread so it maintains tension.
Check that carefully, sometimes that gets overlooked.
Jan 16, 2015 | Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
How to load the bobbin
your manual should tell you as machines differ from make to make. basically ......... your bobbin is usually encased in a holder which is set under your needle, usually accessed through a sliding plate. I have 2 machines and both are different. one is to the front of the machine and one sliding out directly under the needle. turn your wheel to ensure your needle is in the up position. find your access plate and remove the bobbin holder, put the new bobbin in, ensuring some thread is pulled through the small gap in the side wall of the bobbin case. put it back in. gently hold onto the thread in your needle then slowly turn your wheel towards you. as the needle goes down it will pick up the thread below and bring it up, when this happens put both threads to the rear and you are ready to sew. if you don't have a manual you can usually order one from the maker or try managemylife.com
May 16, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Bobbin holder won't stay put
If the bobbin case/holder is trying to lift up and the thread is staying partly around it, your bobbin case may have turned part way.
Remove the needle plate and the bobbin case. The outer edges of the bobbin case should be very smooth. I suspect you may see a needle hole in the flat area that was under the foot. If so, you will probably wish to take it to your dealer and show them. They may smooth it or recommend replacing it. When the bobbin case is placed back into the hook cup that it sets in, the retainer at the 11 o'clock position on it should only allow the case to lift up about 0.8 to 1mm at the most. If it will lift up more than this, press down firmly on the retainer and move it closer to the bobbin case. You must have enough room for the thread to pass between the retainer and the bobbin case, but too much clearance will allow the bobbin case to turn in the machine and it will be damaged by the needle.
Apr 09, 2009 | Husqvarna Viking 1
Needle won't pick up bobbin thread - HELP!!!
I recently fixed my wife maching with the same problem. I found that the screw had come loose that holds the linkage together that rotates the bobbin holder. I was fortunate enough to notice the screw while looking at the machine. To replace it requires taking both the front and back covers off of the frame since the bobbin holder linkage is in the rear behind the needle area. Be careful to insure that the plastic toothed "rail" that runs the bobbin holder is positioned properly or it may break off a tooth. Once I replaced the screw and put the machine back together, it picked up the thread with no problem. Hope this helps.
Dec 27, 2006 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
49 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
