Question about Cambridge Soundworks CD-740 Clock Radio
Cd 740 was working fine yesterday. When I moved it to a different outlet it came on for a few seconds then quit.
    President:
  • 1,961 Answers
Hi, your power cord might just get defective.test them by wiggling the cord while it is plug inn see if it power on then stops.the cut must just about 5 inches from the plug of your radio.you can just replace the plug or replace the whole cord..thank you and good luck!
Posted on Mar 13, 2011
What would cause it to run fine yesterday, start up this morning, then just quit? it will start, run a few seconds, and quit. the fuel pump is working.
This issue could be related to many factors. Fuel pressure, no spark are possible causes, just to neame a few. Verify these two important things and comment back.
Feb 17, 2011 | 1995 Jeep Grand Cherokee
CD will not eject from unit.Word'IN' keeps
you can try either pushing the reset switch (which will be a small indentation either on the face or the subpanel behind the face) or disconnect power to the radio for a few seconds.
Nov 30, 2009 | Car Audio & Video
Computer will not load up - frozen on acer start screen?
Are you sure the monitor is plugged into the correct port? Also, check the monitor cable for bent pins. A small move shouldn't make this kind of difference. Eliminate that power strip and just plug the computer and monitor into an outlet.
Mar 24, 2009 | Acer Aspire™ T180 PC Desktop
Car will start but won't stay running
Hi!
I'm presuming the B23 engine? Have you checked fuel pressure valve located on the inlet manifold, are your plugs getting soaked in fuel?
If not try looking at the Fuel relay in the block situated behind the ash tray below the Radio.
It might be easier for you to access this by taking out the coin tray, flip the cover plate off the cigar lighter it will reveal 2 screws, take that out and the tray then you'll see a whole lot more relays.
There are different types/colours I'm guessing your could be Blue but there are white ones too.Try Jiggling them carefully then crank the engine if it runs but poorly replace.
You must replace with correct one even if it is Blue some have Copper Lugs others steel and they are different.
Good Luck!
Paul 'W'
Jan 04, 2009 | 1989 Volvo 740
Hp dvd740 doesn't read any blank discs..
you're starting to experince laser pick up failure, maybe starting to weakened. Try using a cleaner first and it could be dirty nor with carbon deposits. If still the same then i dont know of any shop repairing DVD drives, it will be up for replacement only.
May 31, 2008 | HP dvd740i DVD±RW Dual Layer Burner
Bose Lifestyle 12 Porblems
sorry mate, looks like cd 5 is damaged goods...... wheter you damaged it or not, can't say....
however, make sure. when you try to play cd, that the cd button, nearest display was pressed as just putting in a cd isn't automatically taking control of the cd function like in other cd players. ( that is to say you have to diliberately select CD mode to play cd's)
if you fancy a load of electronic messing and visits to radio shack i am sure you can repair it if broken,
or a second hand cd unit could be obtained elsewhere on line.
Jan 02, 2008 | Bose Lifestyle 12 System
Olympus Camedia C-740 Ultra Zoom Digital Camera is not powering on
Battery contaxcts probably- clean the contact inside the chamber and the cover. In side use the eraser on the end of a pencil. Also when switch on -press in the cover - it is possibly a loose contact.
Jun 28, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Heater will not operate!
did you take it apart to see if the switch is good or the thermostat was functioning?  without looking inside, other than saying it don't work, isn't going to solve anything.
Oct 16, 2006 | Holmes Products HOLMES COMPACT OIL FILLED...
Cambridge Soundworks CD-740 Clock Radio Logo
134 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
