Question about Home
Water shoots out from under the lid of my toilet?
  • 349 Answers
Water coming out from under lid there is two thing's to check. Fill tube from fill valve line may have come out of stand pipe and spraying under lid. And the next thing to check is the top of fill vlave maybe leaking and sparying water from it causing water to come out.
Posted on Mar 14, 2011
The toilet tank has 2 dips in the back wall and the lid does not cover them. it is allowing moisture to get on the wall and cause mold. should those dips be there or?
yes. Why so much moisture? There shouldn't be any unless you have hot water filling the tank or a spray of water shooting out. Check it out.
Oct 31, 2013 | Kohler Home
Toilet is not flushing
sounds like you need to adjust water level in tank,take lid off and check if theres enough water to flush should be a water level line in tank.
Sep 24, 2011 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
A small leak under the toilette, the seal has been changed many times and the toilette has even been replaced. Plumber says deffective toilettes? The leak seems to only happen when or after it is...
I've installed a lot of Toto toilets and have had few leaks but, not from the one piece toilets. It might be a problem toilet but, I would be sure the drain is not blocked causing a small back up after the flush.I have seen this happen many times. The toilet can be pulled and a 5gallon bucket of water can be poured down the drain to test this before replacing the toilet. also be sure water is not spraying on the top of the tank lid and leaking down the back of the toilet.If you flush the toilet with the lid off it should be easy to see if that the problem. hope this helps.
Dec 21, 2010 | Toto ULTIMATE ROUND FRONT ONE PIECE TOILET...
Water squirts from tank while filling
Take lid off and check that the fill tube is in place. If so flush with lid off to see were the water is squirting from, be prepared to clean up water...If you can, do a slight flush. If there is water coming from any where but the bottom of fill valve and the fill tube you may need to replace the fill valve. In my experience, the fill tube is dissconected.
For Diagram
http://www.askmehelpdesk.com/attachments/plumbing/19906d1242687133-shut-off-valve-under-toilet-doesnt-work-fluidmaster-20ballcock.gif
Jul 06, 2010 | Kohler K-3386-0 Rialto one-piece...
How to fix fill water shooting up and over when flushing?
Hose in tank it has a clip to secure it to a fill tube in center of tank to let water fill down tube . If it is just stuck down in it or loose it has to much pressure and will spray every where.
May 11, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Basement toilet drains slow sometimes ,other times doesnt want to go down all the way. seems as if there is no pressure to remove waste
if the toilet is old or not cleaned proper, the water jets that shoot the water into the bowl might be clogged. If the jets are clogged with moldor hard water build up the toilet will not flush proper. If you can take a 3 gallon bucket of water and pour straight into the bowl and it flushes fine you have a water pressure problem as described above. the problem also might be that your water inlet system is not letting in enough water to fill the tank. If this is the problem you need to replace the water inlet mechanisim, such as a fluid master. If you use a blue water device that hangs on the side of the tank in the back of the toilet you might have a peice of it under the flapper that takes the water to the bowl when being flushed. Check under the flapper if you put cleaners in the tank.
Mar 23, 2010 | Crane Plumbing Toilet To Go Tall...
The toilet recycles every ten minutes
You got a bad seal for sure.  Even though it looks like a good seal.  Open up the lid and see if you got any little bubbles floating up from around the seal or listen for a slow water drain around the seal.  Go to Lowes and tell them you need a Korky flapper.  Their the best thing since sliced bread and peanut butter.
Oct 26, 2009 | Home
Eijer toilet shooting water out of the tank
There is a shut off valve under the stool. turn the water off and go to walmart and get a new valve. Take the one out of your stool so you get the right one. hope i was helpful
Aug 27, 2009 | Eljer & Patriot& Elongated Toilet Bowl
2 Toto Guinevere toilet levers stay up after flush - wastes water
Often the chain or cord in the toilet tank has caught on something. Only lift the tank lid when water has stopped running. When replacing the tank cover, check if vertical water pipe has to sit under the lid just so to catch the vertical discharge, if so designed. Or perhaps the rubber stopper has deteriorated. Good luck
Aug 01, 2009 | Totoku CCL250i Monitor
Home Logo
61 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
