Question about Epson MovieMate 25 Multimedia Projector
System over heating,,,It says check filter - Epson MovieMate 25 Multimedia Projector
  • 442 Answers
Have you checked the filter
Posted on Mar 14, 2011
What 90,000 maintance needs to be done on 1998
Hyundai recommends the following service items for vehicles at 90000 miles:
  • Air Filter Replacement
  • Spark Plugs Replacement
  • Evaporative Canister Filter Replacement
  • Change Oil and Filter
  • Cooling System Flush
  • Rotate Tires
  • Check Brake, Steering and Suspension System
  • Check Parking Brake System
  • Check All Hoses
  • Check All Fluids
  • Check Exhaust System
  • Check Axle Shaft
  • Check Heating AC
  • Check Drive Belts
  • Check Power Steering System
  • Check Steering Gear
  • Check Gas Cap
  • Check Evaporation Emission System
  • Check Emission Control System
  • Check PCV Valve
May 15, 2014 | 1998 Hyundai Tiburon
90000 mile maintenance
Hyundai shows the following as a list of their recommended 90,000 mile maintenance items:
  • Rotate Tires
  • Check All Hoses
  • Check All Fluids
  • Check Axle Shaft
  • Check Heating AC
  • Check Drive Belts
  • Check Gas Cap
  • Check PCV Valve
I have an Air-con air conditioner and heating system
Check your filter, if it's clean check the condensate drain to be sure it's draining if ok your system has a leak and will need an ac tech to repair and recharge the system
Nov 28, 2013 | Air Con 9,000 Btu Split ditioner Wall...
What does service b mean
The A service and B service is an oil change and a long list of inspections. Unless the service is covered under warranty, or this is a new car and you want some piece of mind, I suggest only getting the oil change. The rest of the "service" consists of someone looking for problems with your car. Here's what's included:
A SERVICE (~ $205.95 + tax) :
- Inspect and record tread depth, and correct tire pressure
- Rotate tires (excludes AMG, Sports Models, SLK, and vehicles with staggered wheels)
- Engine oil change and oil filter replacement
-Includes Mobil 1 synthetic oil
- Lubrication service
- Includes hood hinges, lock cylinders, striker
plates, sun roof tracks and top off all fluids
- Cooling system inspection
- Includes antifreeze protection level, hoses and
clamps
- Brake inspection
- Includes check of pad thickness and condition of
discs, fluids and lines
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional. Dust filter prices vary by model)
- Function check
- Includes warning lamps, headlights, exterior
lights, seat belts, windshield wiper and washer
- Inspect and lubricate throttle linkage
- Check and clean air filter
- Reset flexible service system counter
B SERVICE (~ $379.95 + tax) :
- Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*).
- Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*).
-excludes AMG, Sports Models, SLK, and vehicles
clamps
- Brake inspection
- Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model)
- Function check
- Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels
- Inspect Poly V-Belt for condition
- Inspect starting and charging system and service battery
- Inspect climate control refrigerant
Feb 12, 2013 | Mercedes-Benz C-Class Cars & Trucks
No heat in 2003 buick lesabre but engine overheating
The first thing you need to do is check the cooling system coolant level. If it is low or empty, there is not sufficient coolant to cool the engine or to transfer through the heater core to supply the cabin with heat. Fill it up and check for leaks. Once leaks have been repaired, change the thermostat, engine oil and oil filter. If it is full, you may need to change the coolant due to its age, as well as the thermostat, engine oil and oil filter. The reason for the oil change is due to the thermal breakdown of the oil in overheating conditions. Also inspect the water pump to ensure it is being driven by the belt. You may also have air in the cooling system that is causing all your problems. Generally only happens when the cooling system is improperly filled. Make sure you add the correct mixture of coolant and water. Incorrect ratios will cause you similar problems.Coolant protects the cooling system and the water dissipates the heat.
Oct 07, 2012 | 2003 Buick LeSabre
My dryer is taking way to much time to dry a basic load
The problem is either a blocked lint filter or a restricted vent system if the dryer heats up normally or a faulty cycling thermostat if the dryer heats up erratically. Check and make sure the lint filter is clear. You may need to have a contractor have the vent system checked and cleaned as it is necessary to clean them at least once year or every six months if 4 to 5 loads are done everyday. Restricted vent system impedes the airflow and therefore the disposing of the steam it carries. This consequently results in the longer drying time.
Replace the cycling thermostat if the dryer is heating up erratically or does not heat up sufficiently.
Aug 21, 2011 | Kenmore Dryers
Where Is The Fuel Filter Located On A 2003 Ford Explorer V8 And How Do You Change It?
  1. Disconnect the battery ground cable.
  2. Properly relieve the fuel system pressure.
  3. Raise the vehicle on a hoist.
  4. Remove the bolts and the fuel filter heat shield.
  5. Remove the nuts and the fuel filter shield.
  6. Disconnect the quick release and spring lock couplings and remove the fuel filter.
To install:
  1. Remove any fuel line caps.
  2. Install the new fuel filter, connecting the quick-release and spring-lock couplings.
  3. Install the fuel filter shield.
  4. Install the fuel filter heat shield. Torque the bolts to 15 ft. lbs. (20 Nm).
  5. Reconnect the battery ground cable.
  6. Lower the vehicle.
  7. Start the vehicle, check for leaks and repair if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 26, 2010 | 2003 Ford Explorer Sport
Klimaire KSWG009H113 Split System Air...? system
check your filter if its really dirty it will decrease your air flow
Feb 07, 2010 | Cfm Klimaire KSWG009H113 Split System Air...
The heater is not keeping the temperature
OK maybe it's not the thermostat. Without a make and model number of your heating system we will be shooting in the dark. If you have a furnace or air handler, check the air filter. Get in front of the heating system and give us details as how it is running, noises, temperature of components, etc... We can isolate the thermostat by jumping the wires going to R and W on the thermostat. If the system chugs away we know that the heating system is fine (with the exception of the air filter) and is not the problem. If it still has a problem getting to temp, then it is a heating system issue. Get back to us with info. Thanks.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
Epson MovieMate 25 Multimedia Projector Logo
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
