Question about Shimano Cycling
We have Schwinn bike w/Nexus Inter 7 Shimano hub SG-7C21. This bike has coaster brakes. Have a flat tire need instructions how to remove rear wheel and reinstall. We are 25 miles from a Schwinn Dealer, with price of gasoline don't want to drive 50 miles to have wheel removed, who knows, might have to do it again soon, tires and tubes are over 12 years old. Thanks. Chet Korff
    Brigadier General:
  • 8,546 Answers
Many videos when you Google "remove rear wheel nexus"
http://www.dailymotion.com/video/xdf7ur_beachbikes-com-remove-wheel-with-sh_school
Posted on Mar 13, 2011
Aseemble a coaster brake on a bicycle
Ken, Check the attached links,instruction and guides on removal and install coaster brake. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Coaster Hub Overhaul Pedal Brake Hub
How To Install Cog On Coaster Brake Hub
Bicycle Coaster Brake Repair and Service
Oct 01, 2014 | Husky 26"" x 2.125 Industrial Chrome...
Assemble rear axle for a bycle
There are several different varieties of rear coaster brake hubs. The most common is a "Shimano". The easiest way to tell you how to reassemble is by referring you to either Utube, put "shimano coaster brake in search box or go to SheltonBrown.com. Again enter the shimano in the search.
Sep 18, 2014 | Coaster Brake Hub Kit Chrome Bicycle Bike
Shimano Service Manual
What sort of hub is it? The one that runs in oil is the Alfine - the others are greased, in my experience, although there is an dealer-approved means of refreshing the grease in a Nexus hub by dunking the internals into oil.
The Alfine 11 speed needs 25cc of Shimano SG-5700 oil assuming all the old oil has been drained first. This is according to a Koga Miyata manual for a bike that uses this hub.
May 20, 2013 | Shimano Internal Gear Hub Maintenance Oil...
When coasting the pedals keep moving so you have to continue to pedal and when peddling backwards the bike goes backwards, how do I stop this?
I assume that this bike normally has a coaster brake. If so, your coaster brake mechanism (inside the hub of the drive wheel) is jammed or broken. You will have to disasssemble the wheel hub. This bike might have a coaster brake on both rear wheels or maybe just one side. Lift both rear wheels off the ground and turn them independently to determine which side the problem is on.
Sep 18, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
The coaster brake on bike doesn't work, when pressing the pedal back, it just rotates and the brakes don't grab. What could the cause be?
Perhaps the torque arm is not attached to the chainstay. The torque are is a metal bar about 3 inches long X 1/2 inch wide, and the chainstay is the tube of the bike frame that runs from the pedals to the rear wheel hub. There is usually a little metal clip that wraps around the chainstay and is attached to the end of the torque arm with a small bolt.
Sep 02, 2012 | Electra Bicycle Company Rockabilly Boogy
Removal of rear wheel with internal geared 3-speed and coaster brake hub
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Feb 24, 2012 | Cycling
I need complete instuctions for a rear hub assembly for a 2010 Schwinn Delmar Cruiser
Who makes the hub? Most likely Shimano. Try their website. Web search "(brand) coaster brake hub".
Sep 14, 2011 | Cycling
Trying to find an online manual for for the Shimano 7 speed hub SG-7C21
If there is one available it will be at www.shimano.com
Dec 30, 2010 | Cycling
Cycling Logo
839 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
