Question about Neff H7871N2GB Convection / Microwave Oven
The appliance does not work at all, there is no sign of power to the appliance. I have ensured there is power to the socket and the fuse within the plug is o.k.
  • Neff Master
  • 8,404 Answers
Remove the cabinet and find the fuse which will be near where the power cord enters the device. If failed, replace with the same value and type. Find the proper fuse at your hardware store. Still dead? Time to call a pro for repair.
Posted on Mar 13, 2011
All functions have stopped. The appliance is dead. Tried another socket same result. Any possibilities?
You probably have a blown fuse. Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 17, 2015 | In Microwave Ovens
The trip breaker in my home for the electrical outlet keep tripping off what do i do. the breaker in my electircal box for my electrical socket keep tripping off
go to the qualified electricians on your place... but there is some helpful tips that can help you.. (1) for continued protection before starting. turn off the main circuit breaker. (2) unplug all the appliances or equipment installed... (3) check all the wall socket outlet... look for any damages on the wall socket... if the wall socket outlet have no signs of burned or wet marked, try to turn on the circuit breaker. check if the problem is solved.. (4) if the wall socket outlet have a signs of burned or wet marked.. just replace that w/ the same type of socket... check also the appliances that may caused the problem... the easiest way to know is to look at the socket plug itself... ty
Jun 21, 2011 | Microwave Ovens
I have a GE Advantium Oven that just suddenly quit working...no signs of life. Could it be a fuse and if so, where is it located on the unit and where can I find one to replace it?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 18, 2011 | GE Advantium 120 Convection/Microwave Oven
GE JVM1190SY/WY My microwave shows no signs of receiving any power. The light won't even come on. I have tried plugging it in to several different outlets, all of which tested good for a 120 volts. ...
Hope this helps.
Jan 10, 2011 | GE JVM1190SY/WY/AY/BY Microwave Oven
Model#85410 just shut down completely. power to socket but microwave is completly dead.
Hope this helps.
Jan 02, 2011 | Microwave Ovens
Unit is showing no signs of power. Mains fuse has been checked and replaced.
Hope this helps.
Jan 01, 2011 | Neff H7871N2GB Convection / Microwave Oven
Maytag over the oven microwave. Made funny noise and quit working. no light , no clock, no sign of life. Checked circuit breaker, ok. Any ideas?
Hope this helps.
Dec 31, 2010 | Microwave Ovens
MT275 WONT POWER UP AFTER POWER CUT FUSE IN PLUG OK
If you feel confident enough to open the device and are aware of the safety issues regarding the large capacitor within the device (which will hold a significant charge even with the mains disconnected) then it is worth checking the internal fuse within the microwave oven itself.
Occasionally a power cut or a brownout will blow the internal fuse before the fuse in the plug or distribution board.
*** DO NOT OPEN THE DEVICE UNLESS YOU ARE CONFIDENT AND SKILLED ENOUGH TO GROUND AND DISCHARGE THE MAIN CAPACITOR IN THE DEVICE AS IT HOLDS A HIGH VOLTAGE CHARGE EVEN IF THE APPLIANCE HAS BEEN POWERED OFF FOR A CONSIDERABLE TIME ***
Mar 25, 2010 | Whirlpool Microwave Ovens
Microwave doesn't work after house fuse blew
Check the fuse inside the microwave. Unplug the power, remove the case screws on the back of the main case and slide the case toward the back. Remove the outer case and look for a fuse that looks simular to an old automotive fuse, usually near or just above the control panel. Check the fuse to see if it is good, if not replace with the same and reassemble reversing method used to access the fuse. Note: automotive fuses will not work. A replacement will be available at The Shack or a local appliance parts store.
Nov 09, 2009 | Microwave Ovens
AFTER 12 MONTHS ON NO PROBLEMS IT WONT WORK. IT DOESNT GIVE ME DISPLAY LIGHTS OR ANY.
most likely the internal fuse
be soooooooooo carefull in replacing this , the capacitor inside the machine can store a huge charge
  1. Turn off all electricity to the microwave and unplug from the wall socket. Move the unit to a well-lit location to better see the appliance.
  2. Step 2 Usea schematic for the particular model of microwave being worked on tolocate the area containing the fuse to be replaced. Fuses can belocated behind the microwave door or behind a panel either on theinterior wall or an exterior panel. Often the fuse will be behind apanel located under the louver vents on top of the microwave.
  3. Step 3 Removethe panel according to the manufacturer's instructions. Use a screwdriver to remove screws and set aside for replacement.
  4. Step 4 Locatethe blown fuse and check with a voltmeter. This step ensures that theproblem with the microwave is indeed a blown fuse and not anotherissue. Check for current between fuse connectors.
  5. Step 5 Take the blown fuse to a local hardware or store such as Lowe's or Home Depot. Staff can assist in finding the exact replacement fuse for the model being repaired.
  6. Step 6 Placethe new fuse into the panel in exactly the same fashion as the blownfuse came out. Replace any panel using the removed screws and returnthe unit back to its proper location.
  7. Step 7 Plugthe microwave into the wall socket and turn on all electricity. Testthe unit by ensuring the clock and all other features function.
Oct 21, 2009 | Emerson Microwave Ovens
Neff H7871N2GB Convection / Microwave Oven Logo
134 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
