Question about Homelite ZR10926 16" Chain Saw
How do i removed the clutuch from the crankshant on a homelight chain saw
  • 95 Answers
They unscrew counter clockwise.You can use a punch and hammer to knock it loose.
Posted on Mar 13, 2011
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
On Homelight 3816c what is the position position of chain brake when cutting
Easy enough to test which position is correct. With the saw not running of course, Try each position the one where the chain moves freely is the correct position. Most likely on this saw it will away from the bar (rearward).
Nov 16, 2014 | Garden
Homelight service mamual for chansaw Ut 10560
If it is pouring out you can adjust it but if it is not bad dont worry about it. you want a lot of oil coming out of it that is what keeps the chain lubricated this is very important otherwise you will burn the bar up and that will not be good
Sep 10, 2014 | Homelite Gas, 16 In. Bar, 38 CC, Chain...
Need a manual for homelight textron super ez automatic chainsaw serial # 292740092
You can download then print your Homelite manual by going to www.homelite.com/service/product owners manuals the best way to do it is to right click on the material, left click save, put in in your Documents folder, then retrieve it to print if you actually have to hold paper. Good luck
Sep 23, 2011 | Homelite ZR10926 16 Chain Saw
Is it possible to get a manual for a chain saw from about 1970
Hi sann420...
It may be possible to get the user manual on line for an old chain saw like that.
There is some website around that has old user manual, but normally at a cost.
If you want to try to locate a manual for your old chainsaw, then you need to search the web the way that a pro does it...Keeps it simple.
Go to you google search box and put in the name of the maker of the saw
(as an example Homelight 16234 ) followed by the words "user manual"...The search will tell you if yours is available in the results, you might be very suprised.
Please take time to rate me
Aug 30, 2011 | Homelite Garden
Change blade
all chain saws have a sprocket that the chain runs on this sprocket is what make the chain rotate on the bar. the bar is the long part that sticks out in front of the motor. you must remove the side cover of the saw to access the sprocket region of the saw. be sure the saw is unplugged and then remove side cover the bar is usually held in place by a couple of bolts. on gas saws these two bolts also hold the side cover in place and must be removed to replace the bar and chain. once you have removed the side cover look for bolts holding the bar in place. if you only want to change the chain then you may be able to only loosen the bolts or screws holding the bar in place.there should be a screw to adjust the bar forwards and backwards. this screw put tension on the chain so when you put a new chain on turning the screw will proberly tension the chain /do not overtighten the chain.
also be sure you put the new chain and blade on the same as the old one that comes off trying to cut with a chain that is on backward does not work. last note if you are replacing the blade because the old one is dull take the saw to a saw shop they can sharpen the exsisting chain and save you money.
Jan 24, 2011 | Remington Electric Chain Saw
Flywheel to mag. clearance
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 21, 2010 | Homelite ZR10926 16" Chain Saw
Rebilted carb.replaced fuel line start if u put gas in carb will not run old saw but comp. is good. rebilt befor. with no problem 330 homelight.one line go to the fuel tank where do the other line go to...
Your fuel line may be pinched off where is routes to the carb.
Check and make sure that the vent in the fuel cap is clear so you are getting air in the tank
Spark to the plug?
Second line to body of saw is the vacuum from the lower 1/2 of cylinder
Mar 08, 2010 | Homelite ZR10926 16" Chain Saw
Replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Jul 07, 2009 | Remington 16" Electric Chain Saw Assembled...
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Homelite ZR10926 16" Chain Saw Logo
41 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
