Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
The 2wire adapter won't pick up the signal from the modem. The adapter light blinks about ten or twelve times and then turns off. It does this over and over.
    Guru:
  • 811 Answers
You are not getting a signal from the DNS provided by your IP this can be a problem as you know especially on the weekends I deal with this on my network. This is my fix others may have other ideas so read them all. Unplug the computer from the wall the modem the router etc then do a hard boot by pressing the power button on for about 2-3 seconds.
Now start the computer and the modem and the router by plugging everything in. Let it all settle down then go online and see if you are set up. The best way also I use IE8 and let it troubleshoot the problem this will usually solve the issue. I hope that this assisted you. Thanks for using FixYa! do not forget to vote for me. John
Posted on Mar 13, 2011
My 2WIRE router won't give out wireless signal.
Unplug the ISP modem and the 2wire, Check ALL cables and reseat connections, plug in the ISP modem, wait for selftest, plug in wireless, wait for selftest, does your wireless SSID show in Available Wireless Networks on the Laptop? Can you connect using a Ethernet cable to verify it's getting a signal? Contact your ISP and have them verify the signal, have a ISP tech come out to analize the signal, it may be outside?
Feb 07, 2013 | 2wire Computers & Internet
My DSL 2wire modem always blink like crazy.
DSL light blinking green/red indicates you do not have a solid connection to your DSL signal. Typically this can be anything from the connections at your home all the way to the connections with your ISP. As I do tech support for this model of 2wire modem all day long here is what I would tell you to do if you were calling me:
Are you using the proper length of phone cord (15ft or less): people sometimes have a longer phone cord in use and while it MAY work for a while outside conditions will effect the DSL signal enough that it no longer cuts the mustard. The longer the phone cord the more resistance a signal has in reaching the modem.
Filters: Typically the 2wire modem comes with 3 1-way filters and a single 2-way filter. Often people put the wrong filter on the modem, which doesn't even require one, or they put the correct filter (2-way filter) but hook it up to the wrong end (that is to say it should be connected to the DSL side of the filter). All other devices in the house such as phones, fax machines, Tivos, DVRs, Sat TVs, and monitored alarm systems (AKA anything ELSE connecting to/using the phone system) should be on filters.
Phone service: Do you have phone service? Do you have a dial tone or static? If so all problems with phone service will effect your DSL service as that is how the DSL service is piped into your home...that is to say through the phone line. Do not contact your ISP for this problem as it is a phone line problem creating your internet problem.
Phone jack location: Have you tried moving the modem, it's power cord, and proper length phone cord to another jack? Granted the argument that "it worked yesterday, so it should work today" is a strong one but sometimes putting the modem on another jack JUST to test out any potential wiring problems is a helpful one and could save you a lot of frustration. If one jack gives you red/green DSL lights and the other gives you solid green...that should speak for itself.
ISP provider: IS your service turned on? It may be a bit...hmmm...how shall we say....obvious but if your service has been turned off, or not even turned on yet, then that would be why. In addition, if the above does not help in determining what the problem is, a technician may need to be dispatched to determine where the fault lies. Sometimes it's the box down the road and sometimes it's a few miles away.
Jan 15, 2010 | 2wire (1000-000057-000) Modem
Hi - My 2wire 1701 gateway has steady green power light and steady local network light but the broadband link light is steady amber. My computer is receiving the WiFi signal but I cannot get any internet...
The broadband link light tells you the status of the connection between the modem and the broadband servers in your area. Green means everything is A-Ok while amber means your modem is not picking up a broadband signal.
Try turning the modem off and on and also make sure the cables are secure while you're at it. If the broadband light is still amber, the only thing you could do next is to call your internet service provider.
Oct 01, 2009 | 2wire Computers & Internet
Wirless router not working
it seems to be a problem with your ISP.May try these steps.
1. disconnect the router from the computer and the modem.
2. now connect the Ethernet cable to the modem & to the computer and see if that works.
else contact your isp.
for more help.
moz-screenshot.pnghttp://www.ikarmatech.com
Sep 08, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
RED POWER LIGHT ON 2WIRE 2701HG-B
Red power light on the 2wire wireless gateway indicates a device failure. Replace the gateway..
Jul 10, 2009 | 2wire (1000-000057-000) Modem
2wire modem power light red
Its Due to AC adapter capacitors. Capators dry out after certain usage that cause unfiltered output of DC. Add about 2 or 3 pieces of 1000uF capacitor on DC way issue will be resolved. Or simple change the capacitors in AC adapter or change the AC adapter to new one.
Jun 10, 2009 | 2wire 2700HG-B Router (2700HGB)
1800hg 2wire modem problem!
try to use another power adapter with the similar power output aside from what came with your 2wire modem if you have one, if it works fine that means the original power adapter is busted and i think it is also covered by the warranty, get a replacement from the store where you purchased it.
oh by the way, it's normal for all of the lights on your modem or router to blink when you initially power on the hardware, usually your hardware will perform a system check for several seconds to verify if there is any problem after that, several lights if not one should remain steady like the power light, the other lights on the other hand like the ethernet(LAN) or the wireless(WLAN) will most likely flicker from now and then because it indicates activity between the modem and the device/s attach to it.
Hope that answer your concern about your 2wire modem.
May 09, 2008 | 2wire HomePortal® 1800HW Router...
2wire HomePortal - green power light blinking
disconnect the power adapter. Reinsert the power adapter directly into the wall socket. Remove any power strips or surge protectors temporarily to ensure that these items are not preventing the 2wire's proper operation. make sure you are using the power adapter that came with the modem. Plug the power adapter into a different wall socket in another room.
Apr 07, 2008 | 2wire HomePortal 1000HW DSL Modem and...
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
60 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
