Question about Linksys WRVS4400N Wireless Router
I have a linksys expander but it doesnt want to connect to my wireless router
Did you assign the wireless mac address of your router on your extender ? Whats the brand of your router ?
Posted on Mar 14, 2011
What range expander should I use with a Linksys Dual Band Wireless-N Router Model WRT 320N?
For this router you can use the Linksys range expander model WRE54G v3 take not of the version number that is important since the older range expander don;t work on all routers.
Feb 13, 2011 | Linksys WRT320N Wireless Kit
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
    The range expander helps to extend the range of wireless network...
    Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
    your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
    Site survey searches for the available wireless networks in range...
    It should show your existing wireless network...
    You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
    exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
    Thats it...
    You are done...
    Your wireless network range would have extended now....
    Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Rage expander
    Yes that should be possible to configure a range expander with your router.
    You can follow the steps from this link on how to do that
    http://www.fixya.com/support/r4073242-configuring_wre54g_wireless_router
    Apr 13, 2010 | Linksys WRT160N Wireless Router
    No connect to router wireless, no wizard
    You have to make sure that the settings on your wireless router is exactly the same as your wireless expander. Before you place your wireless expander to the spot you want to extend your wireless network, you may want to test it first when it is 10ft to 15ft away from your wireless router. Just to make sure you got it working. And then just keep on moving your expander every 10ft until you reach the farther spot that the expander can reach with good connectivity.
    Jul 01, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    I need to expand my att dsl coverage with an range expander but don't know which one to use. I have a 2wire modem but can't get an answer from ATT about which range expander to use or where to get it
    Linksys makes a simple range expander you can use. Most expanders do not need to be connected to the network by a data cable. Just put it within range of your main access point or wireless router, and it "bounces" the signals out to remote wireless devices.
    Try the Linksys WRE54G ($70-$100)
    Jun 16, 2009 | 2wire 2700HG-B Router (2700HGB)
    Wireless g range extender
    Hi there ....
    before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
    1) either which, please do verify your wireless settings of your DLINK router
    -- the network name or ssid
    -- security if you enabled any on your router
    -- wireless channel
    -- please check the default gateway of your router if it is 192.168.1.1
    ** please take note also that the best location for your expander would be inbetween your router and your computers
    2) once you have gathered the wireless settings
    -- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
    3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
    Thanks and good luck!
    Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
    Linksys wireless G range expander
    Hi David,
    I need to know that what type of router u r using.
    If it is Linksys router just follow these steps,
    with the help of the Ethernet cable connect the range expander to any one of the 4 ports in the router...
    ur computer shuld be directly hook up to the router..
    open internet explorer in ur computer..in the address bar type in 192.168.1.240(ip address of the range expander)
    it will prompt for a username and password...leave the user name blank and the password will be admin.
    u can see the linksys range expander set up page...
    u can find SSID at the bottom of the page...
    ur router's SSID and the range expander's SSID should be same..and also the password should be same..
    If the ssid or password mismatch between the router and range expander u can find these kind of Error messages...
    Good Luck....try it and revert back
    Jul 03, 2008 | Linksys Wireless-G Broadband Router
    Linksys Range Expander...
    Initially, it is possible that the WRE54G has not been configured to talk with WiFi AP/Router downstairs and all that is needed is to configure/set it up.
    Setup (to be done in the same room where your WiFi AP/Router is installed and preferably with your daughter's laptop which can already connect to your network when it is near):
    1. Download the LinkSys WRE54G Setup Wizard from the LinkSys site;
    2. Use a LAN cable connection to the WRE54G Ehternet port (located underneath a flip lid in front panel) to one of your daughter's laptop;
    3. Power up the LinkSys Expander;
    4. Press the Range Expander’s Auto Configuration button for about five seconds. Normally this should be sufficient for the Expander to auto-detect and auto-configure itself;
    5. Power off;
    6. Move the Expander to your intended place of installation;
    7. Again using your daughter's laptop, expand/install the downloaded LinkSys Setup Wizard. Soon as the program is running, follow the on screen instructions. Please don't forget to Save before exiting.
    8. Move your daughter's laptop to its intended location and try the system.
    Should you still need a User's Guide, it is available here.
    Another possibility that we cannot discount is that the WRE54G is also not reaching your router downstairs. Perhaps what can be done is installing it not a floor down from your daughter's but halfway between your daughter's floor and your office downstairs.
    Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
    Good luck and kind regards.
    Nov 16, 2007 | Linksys Wireless-G Range Expander (WRE54G)
    Linksys WRVS4400N Wireless Router Logo
    49 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
