I have a washing machine indesit iwc 6095 and from the begining i had problems.You plug the cable to supply,you select the program(lets say no. 4 ; 40 degrees and 900 rotation),in this time START led is flashing,after this press start ,the first thing is taking water around 10 sec ,after sudenlly stops,automatic drains the water,all the leds are start flashing and i hear the drain pump not stoping until u unplug the cable.I've had read the troubleshooting but in this case all sollution are allright. Please help me with this problem,i can't esed anymore. thanks and best regards.
I have the same problem with same machine. May be factory defect with controller
Posted on Nov 30, 2011
F06 error on indesit WD 61451 washing machine
Could be the program select error, but why not check all error codes and save them on the Indesit site yourself.
Error Codes Indesit Service
Feb 25, 2015 | Indesit Washing Machines
Indesit iwc 6165 washing machine wont heat water
remove the plug first
heater may be shot need to check it and the wires to it
Jun 28, 2014 | Indesit Washing Machines
Indesit IWC6105 Keeps filling with water and lights flashing
Almost certain to be a power pcb failure due to the fact it fills and drains at the same time this is a regular fault symptom on indesit laundry appliances. Word of caution tho inde pcb's are generic to a range and the software must be programmed via a lap top to your specific appliance so you can't just order a pcb and pop it in sorry
Dec 08, 2013 | Indesit Washing Machines
How can get service manual of indesit iwc 5085 washing machine
If u really really need to via the indesir home page it can be ordered as a spare part but they aren't cheap nor particularly helpful
The washing machine doesn't recognize its washining programs. I have to reset I suppose but how? Indesit w123
u select any program then turn off by the wall then you turn on and select another and turnoff by the wall wait 10 mins then turn on select the program you want and will work, theres another link on the internet somewhere ive seen it.
Nov 29, 2009 | Indesit W 123 Front Load Washer
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Indesit wia111 stuck on spin cycle
OK - Try this:-
1. Position the dial on number 0 (off) and then unplug from the wall.
2. After at least 24 hours plug back in - hopefully the thing should have reset.
3. This is really important. Select a wool wash program (No 9) and allow it to complete the entire wash until the door lock light starts flashing to say it's finished.
4. Turn the dial back round to position 0 and all LEDs should go out.
That's it - The control board is reset and all should be well
In order to prevent re-occurance, try to avoid canceling programs mid-cycle. It's also a good idea to switch the dial to number 0 and switch the machine off at the wall when not in use if at all possible.
Please let me know if this works for you :)
Jul 30, 2008 | Washing Machines
INDESIT WIA 101
Press "end of cycle" for 3 seconds, & tell me what happened.
You will rate me also.
Jan 19, 2008 | Indesit WA 115 Front Load Washer
Washing Machines Logo
1,253 people viewed this question
Top Washing Machines Experts
