Question about Panasonic Lumix DMC-FS3 Digital Camera
How do I remove the memory card from my Lumix 8x Vancouver 2010 camera?
  • 3 Answers
The card is in the battery compartment. On the bottom of the camera, slide the release lever in the direction of the arrow and open the battery/card door. To remove the card, push the card until it clicks, then pull the card out upright. Hope this helps.
deanivie
Posted on Mar 13, 2011
Testimonial: "Thanks very much for the advice. Your instructions worked."
Camera model: panasonic FS3 Lumix cannot remove memory card. know how to remove battery. memory card seems stuck or I don't know the trick to remove
Turn the camera off first.
To remove the memory card you have to push it down a bit, you may hear a little 'click' and as you let go the card will pop up a bit.
Then you can pull it out.
Let me know. Thanks.
Jun 16, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
How do i get the 5 internal photos off the camera? I have a panasonic lumix...help!
Remove the memory card from the camera, go into menu and locate format, follow the prompt to remove all pictures, when completed memory card can be installed and normal operation expected.
May 03, 2011 | Panasonic Lumix DMC-LZ5 Digital Camera
How do you remove photos from the internal memory of lumix dmc-fz28?
You can erase them as you normally would when you have a memory card in.
To access the pictures in the internal memory, you need to remove any memory card that you have in your camera first. Then go to preview mode, push the trashcan icon and select "Yes" when asked if you are sure you want to delete the picture.
That's all!
Feb 09, 2011 | Panasonic Lumix DMC-FZ28 Digital Camera
I have a : panasonic Lumix DMC-LZ3 Digital Camera
Page 92 of owner's manual for DMC-LZ3 states "Do not use memory card larger than 2GB".
Jul 04, 2010 | Panasonic Lumix DMC-LZ3 Digital Camera
I have a Panasonic Lumix FS42 with an sd memory card. I cannot download the pictures from the memory card onto my computer even when the memory card is changed into a different camera???
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 21, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Cannot download all of pictures onto pc.
First of all, you should forget about using the internal memory...it just causes problems (as you can readily see). Always use a memory card. If any of the pics on your camera are important, you should download them to your computer before continuing. Then, go into the menu and find "reset"...follow the on-screen instructions. Then, with the card out of the camera, go into the menu and find "format"...follow the on-screen instructions. Then insert a blank memory card and go into the menu and find "format" again...follow the on-screen instructions. From this point on, your life will be wonderful.
Feb 02, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
How do I switch between internal memory and memory card?
When you remove the card, can you review the pictures that are on the internal memory? If you can and you want to save them, download them to your computer. Then, with the memory card still out of the camera, format the internal memory.
Oct 27, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Says this memory card is protected - can't take
Kindly follow the steps below
Remove the memory card from the camera.
Look at the memory card very well, you will see a slide switch on the side edge of the memory.
Move the switch to the unlock position.
Put the memory card back to the camera.
You can then start using it.
Thanks
Oct 16, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Copy images from pc to Lumix TZ5 SD memory card?
yes i m sure it would work if you use a card reader instead of using the camera directly connected.. in that case your memory card will just work as the usb hard drive and you can load anything into it..
Dec 27, 2008 | Panasonic Lumix DMC-TZ50 Digital Camera
Panasonic Lumix DMC-FS3 Digital Camera Logo
192 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
