Question about Mitsubishi WS-65411 65" Rear Projection Television
Tv has worked for ever with the remote now remote has failed and the on off swutch doesnt work to turn it on and off How can I program another remote if I can turn it on?
  • 84 Answers
First, check to make sure the front keyboard is not locked out. Press and hold the menu key for 10 seconds then release. If it was locked out, then front panel buttons should work. If no change, you likely have a problem with one of the ten contact switches on that panel. Remove the front speaker grill by pulling it off, then trace the wires from the front control panel (you may need to remove the cover off the front of TV). Unplug the wires to the front panel and try by Remote control. If the remote works, you can purchase ten tact switches and install or just leave the wires unplugged and use it like that.
Bill W
integrityhomeworx.com
Posted on Mar 14, 2011
Why did my remote that i bought with my rca television stop working to tv an no universal remote will program to it ? could it be the sensor ? because otherwise everything works fine on tv you just ha
Try replacing the batteries of the remote first, and make sure there is no corrosion on the contacts. If that fails, you may have to re-program the universal remote for your TV. If that fails, then you either have a problem with your remote, or the sensor of the TV. Hint, use a digital camera to look at the "light" (LED) of the remote while you press the button. The digital camera can "see" that infrared light, and you can see it on your digital camera screen! This works with dedicated digital cameras, but may not work with smart-phone cameras. For example, it does NOT work with my iPhone, but does work with my Sony digital camera.
Oct 21, 2014 | Televison & Video
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
37lg30 will not turn on w/ factory remote or any other remote programmed to TV. Already tried the obvious solutions - batteries, unplug to reset, etc. Once you turn on the TV manully non of the functions...
I'd check out the IR board on your tv. If you have electronics experience open up th etv find the IR board - trace it back to the AV board make sure all connections are plugged in good then if that doesnt work I'd replace the IR board first. That would be the cheapest part to replace. Also it could be the IR on the remote - but if the codes you used to program the programmable remote are known good for your model i'd look at the tv first.
thanks,
michael
Apr 16, 2011 | LG 37LG30 37 in. LCD HDTV
My remote worked intil I changed my battries in the remote and know it doesnt work. Cant program it to turn on the tv
Make sure you put the batteries in correctly (reversed polarity) and that the batteries are good.
Jan 31, 2011 | Sanyo DP50747 50 in. Plasma TV
Have a Atlas DVR 1055 universal remote from cogeco...i need the code to program my magnasonic tv
You can try these codes :
1913
1928
If all fails you can try the auto search :
Press TV, hold setup until TV blinks twice, press 9 9 1, then press power. and press CH + until your tv turns off,
If it turns off , press setup once to save the code.
If it still doesnt work, then theres no code for your tv in the remote control.
Hope that helps
Feb 19, 2010 | Televison & Video
My remote isnt working for my tv to turn the tv on and the button on the tv is broken. any suggestion on how i can turn my tv on
begin by putting new batteries in your remote. if that doesnt work then go to any radio shack or walmart and get a universal remote which can be programmed to work with your tv. good luck.
Sep 12, 2009 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Doesnt work
try putting new batteries if that doesnt work then reconnect the remote to the tv
Jun 12, 2009 | DISH Network IR Remote Control
Issues program the remote.
go and buy another remote as this is the most useless waste of time when you keep getting the run around and no answers.what does it take to post a page with all the remote numbers on it they all come with the same page.
Sep 30, 2008 | RCA RCR311B Remote Control
Program universal remote
check remote first, and replace ir ditector in the tv...
Sep 28, 2007 | Orion1934 19" TV
Program timer light blinking
The timer light blinks when the AC power has been disconnected and the clock is not set. This is how the set warns you that it can no longer do timer recordings. Setting the clock and doing an autoprogram will fix it, but both the remote and the remote receiver must be working. If the original remote is not damaged and has good batteries in it but does not work on that set and you cannot get any other universal remote to work, then the remote receiver (the IR "eye") inside the set has failed and needs to be replaced. I have seen many of those little receivers failing recently. If you do not have experience changing electronic parts on small PC boards then have a qualified tech change it for you.
Jul 26, 2007 | Panasonic PV-DM2093 Triple Play 20 in....
Mitsubishi WS-65411 65" Rear Projection Television Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
