Question about Husqvarna Freesia 425
While sewing it gave a loud "clunk" then quit
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Husqvarna Expert
  • 300 Answers
Bring it in for service.
Posted on Feb 15, 2013
kent581
  • 87 Answers
SOURCE: Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 19, 2009
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 106 Answers
SOURCE: Singer 7422 bobbin thread bunching up
I assume you checked to see there are no needle bits in the bobbin case holder.
Without looking at the machine it is difficult to diagnose the problem. It could be any one or a combination of problems, timing, needle bar height, damage to the hook and base etc.
I strongly suggest you have it looked at by a sewing machine tech.
Posted on Mar 29, 2008
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
  • 371 Answers
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
My singer curvey 8763 is making clunking noise when start sewing and then stop working
possibly out of time with the bobbin . take in to a shop for checkup
Feb 05, 2015 | Singer Sewing Machines
Not sewing
Suggest open bobbin case to see if loose thread has jammed it.
Apr 18, 2014 | Brother CS-8150 Computerized Sewing...
Wheel won't turn
it's possible that there is a broken or loose part, it would be a good idea to have the sewing machine checked.
Aug 13, 2013 | PfaFF Sewing Machines
My machine will not work. It makes a clunking sound when I try to run it. What is wrong?
it could be the timing, or it mght need a adjustment, or could have
a loose or broken part,, it would be a good idea to have the
machine serviced
Jan 07, 2013 | Simplicity SE3 Computerized Sewing Machine
A "clunking" noise when stitching
some sewing machines have more sounds than others, check to make sure the bobbin is setting securely in the bobbin case,and if that doesn't
solve the noise problem then ,it would be a good idea to have the machine serviced
Dec 31, 2012 | Sewing Machines
Loud clunking noise when sewing. . . then it starts to stutter then it stops & gives me an error. It doesn't occur when reverse sewing though
try these suggestions
change the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin case fits securely into the machine unless it's
a drop in bobbin
if these suggestions don't help then the machine may need to be
checked at a repair shop
Sep 11, 2012 | Brother CS6000i Computerized Sewing...
Clunking noise when sewing flannel new machine
try changing the needle
clean under the needle plate for lint, flannel has quite a bit of lint
make sure the bobbin is turned the correct way in the bobbin case
try rethreading the machine top & bobbin
May 06, 2012 | Brother XL3750 Mechanical Sewing Machine
I have an Elna that I learned to sew on in 1958. It works, but it makes a very loud "clunking" sound that I can feel when I turn the wheel by hand.
Sounds like the friction pulley on the motor has some flat spots from sitting in one place for an extended period of time. The parts are still available from any sewing machine repair shop.
Oct 08, 2009 | Sewing Machines
Sewing Machines Logo
219 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
