Question about Ruud UBHC Air Conditioner
Turn on furnace and nothing happen - Ruud UBHC Air Conditioner
  • 1,420 Answers
Ok, go to the furnace and look for a small viewing port. In it you should see an LED light. If it is blinking you may have an error code. If so, look on the reverse side of the front panel for a wiring diagram and error code diagnostic chart. If no LED, look for an Emergency switch that may have been turned off, blown fuse or circuit breaker or there may be a fuse on the PC board that may be bad.
Posted on Mar 13, 2011
Model mgh-055 furnace. Why won't it light?
Pushing down the button causes enough gas to be fed to the pilot to allow it to be lit and remain burning. If nothing happened, the gas valve could be at fault.
Sep 20, 2015 | Heating & Cooling
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
Peerless Boiler - Turned off boiler to replace Circulator for the hot water. Turned furnace back on. Did not ignite. Tried to hit the reset button for 30 seconds and nothing happened. Furnace will
Did you bleed the air out of the pump. The boiler has a flow switch that has to make before it will let the boiler lite. Make sure you have all of the air out of the system and are pumping or flowing water and not air...Also check to see if you didn't happen to of tripped the limit it has a manual reset. Red Button on the front of limit.
Nov 13, 2013 | Heating & Cooling
On amana furnace when power is turned on the circulator blower comes on and nothing else happens what causes this?
Either you have a safety switch tripped or a faulty circuit board. Test all of the limit and roll-out switches, they should all read closed with an ohm meter.
Jan 18, 2013 | Amana GMH950453BX Gas Furnace
What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Nov 18, 2011 | Goodman Heating & Cooling
Furnace does not work
Is there a booster motor for the burner? I have seen these stick and make a furnace not turn on. The thermostat trips and you hear the furnace click on but nothing else happens. The booster is a small electric motor connected to a small duct. Take the booster motor loose and turn the fan by hand. Usually they will start working after you do this. Make sure furnace is shut off when you do this. Some booster motors have ports to oil them also.
Dec 09, 2009 | Calvin Klein The Field Controls Company...
Pilots stays lite but furnace burners will not turn on. when i turn the knob to on nothing happens
You more than likely need to change or adjust your thermocouple in the furnace. It is the part the pilot light heats up to let the furnace know it is safe to turn on the gas flow. These go bad over time and are fairly inexpensive and easy to change.
Nov 06, 2009 | Heating & Cooling
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
Ruud UBHC Air Conditioner Logo
162 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
