Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a Whirlpool Side by side Model ed25uexhw01 Serial sk4354373 Refrigerator. A thin sheet of Ice forms in the bottom of the freeze side about every other day or so. I can lift it out very easy and throw it away and it comes back again. It looks like a vent of some sort is in the back wall and ice seems to be at the bottom of the vent. The icemaker is not leaking. It seems to be working OK. The drinking water unit in the front seems to be OK also.
    Top Expert:
  • Whirlpool Master
  • 44,045 Answers
Could be defrost water that is failing to drain
Posted on Jun 21, 2017
dididsaythat
  • 291 Answers
SOURCE: Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Posted on Sep 08, 2007
sdmc73
  • 121 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
the module on the icemaker may be bad or the emitter-recever
Posted on Nov 29, 2008
  • 105 Answers
SOURCE: Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Posted on Apr 09, 2009
Sea Breeze
  • 4655 Answers
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on Jul 08, 2009
Whirlpool ED5Lhextd00 side by side ice in bottom of freezer. Cleaned back, ran hot water through, turned off for several hours, leveled off still water builds up and freezes in the bottom
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Refrigerator.
Mar 01, 2017 | Whirlpool Refrigerators
Thin layer of ice on food in ge side by side
ice on food means door was left open for extended period of time and then closed. When door is left open humidity forms on food. when door is closed again the humidity freezes and becomes thin ice
Apr 21, 2014 | GE GSH25JFR Side by Side Refrigerator
Ice forming inside freezer
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
Apr 28, 2012 | Maytag Refrigerators
A sheet of ice has formed on the bottom of the freezer. Why.
There is a drain port in the behind the freezer panel where all of the water drains when your evaporator coils defrost. It has gotten clogged with food, or ice. Thaw all of the ice and unplug the drain hole, and ice will stop forming on the bottom of your freezer.
Jan 30, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side refrigerator - LSC 27950SW - looking
most likely water is running out the corner of your ice maker and into auger bucket and freezing not allowing it to dispense.check bucket to see if sheet of ice is forming.
Mar 06, 2009 | LG LSC27950 Side by Side Refrigerator
Refrigerator not cooling although lights and sound are OK
your condensor had been chocked therefore the gas is not circulating. contact your service authority..... as because it cannot be done by your self.
Feb 27, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
