Question about Nordic Track NordicTrack A2750 PRO Treadmill
Hi! We have a Nordic Track C1250. We are trying to assemble the storage latch but it seems to long. We are trying to move the frame back and forth but it still doesn't fit. What are we doing wrong?
  • shelleyhayes Mar 14, 2011
    We can't get the bar on the machine, it seems to long for the holes provided.
  • 844 Answers
Welcome to FixYa!
Check if the latch knob is facing the correct direction. It should be facing inwards, not outwards.
The upper barrel should insert through the latch knob and lower barrel if the latch knob is placed in the correct direction. Please refer to the image below.
Note that assembling the storage latch is crucial. It can damage the latch knob if installed incorrectly.
I hope this will help.
Thank you for using FixYa and have a great workout!
Jas247
Posted on Mar 14, 2011
  • Jas Barinaga
    Jas Barinaga Mar 14, 2011
    Is it a A2750 Pro or a C1250? The image I posted above is for the A2750 Pro but the principle of installing the storage latch is the same. Make sure that the latch knob is in placed in the correct direction and the upper barrel should be able to insert in the latch knob and in the lower barrel. Loose the latch knob so that you can adjust the length of the storage latch.
    C1250 image.
    I hope that this will help.
    Keep me posted.
    Jas247
  • 2,382 Answers
Hi, there is a lot of weight on the "Storage Latch". You may need to push forward on the treadmill a bit, pull the black knob, then slowly let the machine unfold. Taking the weight off the "Storage Latch" will make it easier to release the latch..
Posted on Mar 13, 2011
Where is the safety latch and how do i unfold the nordic track spacesaver treadmill
Please download the User manualf or Nordic track iFit Coach Plus
and see in the user manual, how to do it.
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 28, 2017 | Nordic Track Exercise & Fitness
I have tried every recommendation as to how to unlock my Nordic Track 1000 from the storage position and nothing works, I am facing the back of the belt of the Nordic Track and pushing forward with my...
Corrine, That knob is spring loaded. You need to pull it out...Hard. Before you do this ,support the walk board/deck frame. It will be free to fall down after hou pull the storage/locking pin out. You need to pull the pin out and hold it until the walk board clears the upright. Then be carfull and lower the walk board/deck/belt.
Hope this helps.
Matt
Dec 08, 2011 | Nordic Track Nordictrack Exp 1000...
I want to move a nordic track power tread pt5.0
HOW TO MOVE THE TREADMILL
Make sure that the pin
on the lock knob is inserted into the slot in the catch.
1. Hold the handrails as shown and place one foot against a
wheel.
2. Tilt the treadmill back until it rolls freely on the front wheels.
Carefully move the treadmill to the desired location. Never
move the treadmill without tipping it back. To reduce
the risk of injury, use extreme caution while moving
the treadmill. Do not attempt to move the treadmill
over an uneven surface.
3. Place one foot on the base, and carefully lower the treadmill
until it is resting in the storage position.
Oct 05, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track treadmill, C1250. Can't install the storage bar, it seems to big.
tread has to be in 0 incline or close but you lift as far as you need to line up the ends of the latch bar installbolts done
Mar 13, 2011 | Nordic Track Exercise & Fitness
How i unfold it?
There is allot of weight on the "Storage Latch". You may need to push forward on the treadmill a bit, pull the black knob, then slowly let the machine unfold. Taking the weight off the "Storage Latch" will make it easier to release the latch..
Dec 16, 2010 | Nordic Track NordicTrack A2750 PRO...
I have a Nordic Track Audio Strider 900 and I have had it for a year. There is now a very loud intermittent sound coming from the back of the machine. It happens rather randomly- but when it comes, the...
Hi We have a Nordic Track AudioStrider 900 and it is squeeking when in use - it's getting so bad that we feel we can't use it. Do you have any advice?
Oct 03, 2010 | Nordic Track Exercise & Fitness
Nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Jun 12, 2010 | Nordic Track Exercise & Fitness
Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Apr 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
My Nordic Track e5 si is rocking back and forth on top of the 3/4'' plywood I've put down under it. How can I stabilize it?
You will need to make sure the four rubber bumpers on the bottom of the machine are in the correct places/or even there.
Tilt the machine on its side and look at the bottom of the frame.
There should be four rubber bumpers, one in each corner. If there are bumpers located in the center part of the frame the unit will be unstable/wobbly.
Good Luck Tim
Mar 27, 2010 | Exercise & Fitness
I have a nordic track a2350 and the belt stopped working, the incline works and the top part lights up. What do i need to do?
This is usually related to the control pwb which is located under the motor "hood".
You can get this part from iconservice.com by going to the replacement parts section of the site and entering the model number of your machine, Which is located on the lower frame assembly below the walk belt. After you have receieved the part you can follow this procedure to repair it.
http://www.fixya.com/support/t3807308-belt_goes_full_speed_when_started_shuts
Jan 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack A2750 PRO Treadmill Logo
365 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
