Question about Roland Dp-10 Damper Pedal-new
Switch on e50 and sustain pedal not holding notes
  • Roland Master
  • 5,603 Answers
I assume you are plugging this into a ROLAND brand product as the Roland sustain uses a normally CLOSED contact while MOST other brands use NORMALLY OPEN contacts.
The Roland synths now monitor the pedal as the power is turned on and supposedly decides which contact type is used.
Remember that for MANY voices, such as piano, notes are held longer BUT they do not continue indefinitely just like the sustain on a real piano works. On a real piano the dampers are lifted, but the strings eventually stop ringing due to the losses of energy in the strings.
Some voices will be held,such as organ tones.
I don't have enough information from your post regarding what voice you are having trouble with.
Posted on Mar 14, 2011
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
May 22, 2012 | Kurzweil SP3X 88-Key Stage Piano
My casio privia px830 pedal doesn't sustain enough,
It could be that the electronics of the pedal are dirty, or that dirt has collected under it causing it to not depress all the way. Try taking it apart and cleaning it with a Q-tip and rubbing alcohol. Be very careful of any wires or delicate articles.
Dec 06, 2011 | Casio PX-830 BK Privia
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Fc4 sustain pedal is in "sustain" mode at all times -- it won't release the sustained notes. I tried plugging the pedal in (to a roland ep-9) before powering up and had the same problem.
Sorry, but the Yamaha pedal has the opposite sense (it is a normally open contact) than what is REQUIRED by Roland equipment. Roland requires a Normally Closed contact. Unfortunately, one is confused because the Roland jack for the sustain shorts itself to no sustain when you unplug a pedal. SOMETIMES one can open a pedal and with soldering iron change a wire to reverse the pedal sense IF the particular pedal has both contacts available.
Jun 16, 2011 | Yamaha FC4 Piano Style Sustain Pedal
When I plug the pedal in and play, the music is constantly sustained without me pressing the pedal. Do i need a new pedal ? Is the problem within my Roland ? Please help ! - I use a Roland 700 GX. -The...
1.Make sure you are plugged in to DAMPER (not FC1 or FC2) 2. Check to see if the notes STOP sustaining when you PRESS the pedal. If that is the case, first try turning off the Roland with the pedal plugged in and restarting with the pedal pressed down. 3. Press the EDIT button and scroll to Damper Polarity. See if it's set to Standard or Reverse. 4. If problem persists after all that, try holding the pedal jack into the Roland at different angles and then try the same with where the cable connects to the pedal. At that point, you can either attempt to repair the pedal or get another one.
Hope this helps, Stewart
Feb 28, 2011 | Roland DP-10 Damper Pedal, B-Stock
When i plug it in to the sustain slot in my yamaha keyboard it makes the notes longer without me pressing the pedal.
You may have a pedal that is ROLAND compatible which is OPPOSITE sense from what the Yamaha requires. The Yamaha takes a NORMALLY OPEN contact.
Some Yamaha keyboards such as TYROS have a parameter that you can set to permit using either type pedal.
Some pedals have a switch to change them to use with either type keyboards.
Feb 22, 2011 | Quik-Lok Quik Lok VP-26 U Sustain Pedals
Is a sustain foot pedal similar to a tattoo machine pedal?
The sustain pedals have only two wires. Usually they terminate in a 1/4 inch mono plug.
yamaha USUALLY sustains when switch is closed. Roland usually sustains on a switch between the wires when the switch is open.
NO POWER should be supplied BY the sustain pedal... it is ONLY a switch.
Apr 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Sustain is in reverse yamaha p-85
I have the same problem, But I have been using the same pedal since new. Infact it came with this pedal. Then suddenly it started doing this. Could I have changed soem setting by accident?
Jul 08, 2009 | Music
Roland DP-2 pedal not functioning correctly.
There are two types of damper pedal switches, on that is closed until you press it, and one that closes when your press it. It sounds like your Casio is expecting one type and your Roland pedal is the other type. A quick way to test this is to plug a guitar cable into the Casio pedal input and see if the keyboard sustains. If it does, then your Casio requires an "normally closed" switch.
Some pedals have a small switch near the cord or even on the bottom of the pedal that will reverse the switching operation (BOSS pedals, a division of Roland, have this feature). If you can find that, then change the switch position and you should be OK.
If not, and you feel like digging into your pedal, you could take the bottom off of the pedal and check out the switch itself. Many pedals use a switch that can be used either way. The clue will be on the switch itself. If there is an extra tab on the switch that is unused, then switch the wire that is furthest away from that tab to that tab. This will probably involve soldering, but it is nearly impossible to damage anything.
If moving the wire that is furthest away does not do anything, then try putting that wire back and switching the other one.
If your pedal does NOT have an extra tab, you're SOL, unless you want to buy a replacement switch (unsure of make). If this is the case, you are probably better off getting a different damper pedal - preferably one that is marketed as "universal"
Jul 02, 2009 | Roland Dp 2 Damper Pedal
My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
May 31, 2009 | Roland Juno-D
Roland Dp-10 Damper Pedal-new Logo
235 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
