Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Sirius Incanto loud noise
Hi: My Saeco Sirius Incanto will not grind any longer. The grinder makes a loud noise when attempting to gind beans. It also will not brew ground coffee. Is this something I can repair? I'm an electrician, and pretty good with tools. Thank you.
  • 515 Answers
When you power on the machine, can you hear the machine do the self test?
is there a crack sound when the brewing unit is in work?
Posted on Aug 08, 2008
  • gisella_azev Jun 25, 2011
    when I start my Incanto Classic i can hear it trying to do the self test and then a loud knocking noise when the brew unit tries to kick in - then I get a flashing error light and cannot brew coffee...all this just after i descaled the machine which I've done several times before - HELP!
On my saeco incanto I get a red light showing no coffee but there is coffee.I'd be much obliged if you have any ideas Regards Frank
HI
Grinder adjustment set too low. Increase the setting to 18 and try again, after it grinds and starts to brew push the brew to stop the cycle. Repeat the steps again. If it works when it is grinding turn the big knob back down but to a mark 2 higher than you had it before. When the grind gets to fine the ground coffee compacts in the grinder and passage way then you get the message bean hopper empty. Making the grind a little coarser prevents the grinds from compaction. If you are using oily beans (Shiney) they can glue themselves together and cause the same symptoms but the fix is the same. Make it coarser. If it didn't fix the problem you will have to dissassemble the grinder and clean, then readjust.bansheracer_14.jpg
Jan 31, 2011 | Saeco Incanto Classic Espresso Machine
Grinder is blocked and have tried screwing the grinder stem but no change is there anything else i can try
Hi hope I'm not too late. But I vaccumed the bean grinder. Unscrew the grinder stem fully open/large grind, place vaccum hose over grinder, turn on vaccum it sucks out any loose 'hard' beans/rocks/stems. Srew down to desired grind and refill - worked for me.
Jan 11, 2011 | Saeco Incanto Sirius Fully Automatic...
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Coffee beans out of message
HI
I hate to tell you this but your grinder is bad. The sensor in the grinder is messed up, and thinks its done grinding after 3 seconds. The grinder will have to be replaced. Sorry
Dec 16, 2009 | Saeco Incanto Sirius Fully Automatic...
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Brand New Incanto, Grinder Doesn't Work
If you look at the adjustment knob in the bean hopper, make sure it is in the middle i think it will be "8".
Make sure you not get any damp into the grinder.
Try to make 2-3 cup of coffee.
Let me know if i can help you more
Best regards
/Mirran
Nov 08, 2008 | Starbucks Saeco Italia Digital Barista...
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic - Bean feed problem
First, make sure you not get any damp into your grinder.
If you get damp into the grinder then it will not grind the beans.
To check the grinder you have to loosen the three screws in the beanhopper and lift it up.
The jagged plastic in the machine you will see when the beanhopper is off, turn it anticlockwise to you can see
the claque is free, then you can take out the jagged plastic and you will see the grinding wheel, make sure the wheel and the jagged plastic is clean.
Before you mount all again, use a vacuum cleaner to clean it.
Put back the jagged plastic again and turn it clockwise to it stop, then you turn it anti clockwise 14"click".
Set the number to 8 on the beanhopper and mount it again.
Hope this will help you.
Best regards
/Mirran
Aug 29, 2008 | Saeco Incanto Classic Espresso Machine
Saeco grinder
What kind of Saeco machine do you have, and how old is it?
Jun 27, 2008 | Saeco Incanto Classic Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
320 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
