Question about Ryobi Cultivator
My ryobi 410r will not start. i use the 50:1 oil/fuel mixture,changed the spark plug and all it does start for a few seconds and then stops.
2 Suggested Answers
  • 277 Answers
SOURCE: fuel oil mixture ratio
I have a 410R still looks like new.
it has on it gas & oil = 40. to 1 for mixture.
mine never gets used so it is still new.
Posted on Jun 23, 2010
How do I fix a ryobi bp42 that will not start
It's a 2 stroke & it's relatively new. as long as you didn't score the piston by neglecting to add oil to the fuel mixture, the most likely problem is fuel issues. It only takes a month or 2 to have ethanol fuel absorb enough moisture to ruin the fuel mix. Return all carb settings to original settings. Empty your tank, get rid of your fuel, remix with NON-ETHANOL FUEL MIXED WITH A PREMIUM SYNTHETIC 2-STROKE OIL, such as echo or husquvarna. Purge all the fuel from your lines and primer. Remove the spark plug & pull the cord a few times to dry out the cylinder, run a flame under the spark plug to dry it out. Add 3 drops of fuel mix to the cylinder then replace the plug. Put it on full choke & pull 1 time. Then on 1/2 choke pull to start in 1 or 2 pulls. Still won't start; replace plug & air filter. Let it warm up for 5-10 seconds then turn choke off.
Sep 13, 2015 | Ryobi Garden
Ryobi ry08576
make sure your fuel is fresh and mix at 50:1
then remove the muffler and try to start it holding the throttle wide open... if it starts and runs fair suspect a flooded engine, plugged muffler
if not, suspect a carb adjustment issue and then a carb
Aug 14, 2014 | Ryobi Backpack Blower 25.4cc
My ryobi 350 cfm 180 mph gas backpack blower just stop andwont start again and my brother in-law said my mixture of gas to oil is not correct,less oil was mix how can i remedy the problem.
PROBLEM Engine fails to start. CAUSE - REMEDY No fuel in tank - Fill tank. Spark plug shorted or fouled - Replace spark plug. Spark plug is broken. (cracked porcelain or electrodes broken) - Replace spark plug. Ignition lead wire shorted, broken, or disconnected from spark plug - Replace lead wire or attach to spark plug. Ignition inoperative - Contact authorized service center.
Aug 21, 2011 | Ryobi Garden
Fuel oil mixture ratio for ryobi 410r cultivator
Jun 23, 2010 | Ryobi Cultivator
I have checked spark plug,spark is strong & blue but still willn't start,what could be coursing trimmer not to start? Should I change fuel mixture,flush fuel lines?
have you checked for the PROPER spark plug gap? this is crucial, and if you have spark and fuel, with the proper GAP it WILL run
Sep 04, 2009 | Ryobi Garden
I have a new 50 cc mini quad for my kids and its bogging so bad it wont move my 4 year old? {2 stroke}
Try changing the spark plug making sure the gap on the new plug is at recommended specs.If the plug is black when you pull it out mix gas with a little less oil but not much as if it is to lean it can burn up motor make sure gas mixtured isn't to rich if you have to mix the gas and oil together yourself.
Sep 02, 2009 | RTO Mini Quads
Gasoline/Oil Mixture
I would not run it any any less that  50/1 ratio.
May 09, 2009 | Ryobi Cultivator
Ryobi lawn hornet mk2
Change your spark plug
If the fuel oil mixture is too oily it will foul the spark plug and no cleaning will get it right.
If there is a lot of oil in the crankcase it may foul the new spark plug so another new one is needed
Aug 10, 2008 | Electrical Supplies
Ryobi RLT30CES
I have one of these and I have to admit they are a bit of a bug*er to start. Following the instructions though on the sheet for trying to start it eventually should kick it off and then you should be away. I start mine by alternating between no choke and the half choke with about half a dozen pulls each. generally pull with the throttle held but try a few with it off every now and again. If you get to 10 mins without success, put it down, have a drink and a rest and go back in 30 mins and try again.
I wouldnt have thought a straight petrol mix would do it any harm though, if you had over mixed with oil then that could have been a differnt story.
May 25, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Cultivator Logo
101 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
