Question about KitchenAid KUDS301VSS Dishwasher
KitchenAid dishwasher model: KUDL031VBL3 Ser: F00602850 it's just sitting there with washing and cancel buttons flashing. It was flasinh washing and not running. I pushed cancel and now both are flasing. Been that way a few days. Need help!
ngfam1
  • 639 Answers
SOURCE: kenmore dishwasher blinking lights
Dear friend,
ngfam at you service! happy to assist!
The blinking lights are called codes and this is warning you that there is a technical problem. Probably an electronic failure some where. This can only be diagnosed by a trained service tech!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
IrishDruid
  • 2712 Answers
SOURCE: ////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Posted on Nov 26, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: the kitchenaid dishwasher (model KUDC25CHSS1)
Press and HOLD the HEATED DRY button for 5 seconds.
Posted on Jul 07, 2009
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light flashes
I have found 2 possible solutions for you to try on your washer. It looks like there are good results on each of the sequences listed so you may try both to see what one works for you.
1) Press normal wash and heated dry one after the other about 5 times.All lights on panel will light.Wait until all lights go out and it resets itself.It will go into a mode on it's own.Then press cancel and set your options as you normally would and press start
On the hidden button models this seems to work, push these buttons in this order:
Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash, close the door, Start, open the door, Cancel 2x
Mar 08, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Clean light flashes, does not cancel,
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 09, 2010 | KitchenAid 24 in. KUDP01FL Built-in...
Kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Sep 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
We have a kitchenaid dishwasher model#kud102irbl serial#FU1705420 Clean light keeps flashing on 7 times, waits a few seconds and flashes 7 times again. How can we repair this?? Dishwasher will not leave...
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 26, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid KUDS301VSS Dishwasher Logo
167 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
