Question about Klipsch KL-7502-THX Speaker System
I cant get any sound from my speakers only the subwoofer will work
  • 604 Answers
Klipsch, usually fuse the speakers. look at the back of your speaker to see if there is a fuse holder, if not, it may be internal and if there is a panel you can take off, do that and look inside for a fuse and check it with a volt/ohm meter if its blown replace it with same value fuse. Aother way you can check to see if the speakers still work is to take a 9 volt battery and touch the terminals of the battery to the terminals of the speaker, if you hear a clicking sound or better yet can see the speaker move in or out the the speaker is good and the problem is elsewhere in your system. if both speakers don't work I would first suspect the fuse in the speakers. you could also try hooking up different speakers to your amp and see if those work, one last thing, plug in some headphones, if they work you will know that at least that part of your amp works.
Posted on Mar 14, 2011
Rca rtd 6151
You may have to connect the subwoofer output to a powered subwoofer.
Dec 01, 2013 | Audio Players & Recorders
No sound through external speakers from samsung f467000
recheck the inputs and outputs sounds like you crossed them
Nov 18, 2013 | Samsung Audio Players & Recorders
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Computer speaker problem
Make sure the cable connected to INPUT directly connected to your sound card on GREEN plugin
Best Luck!
Dec 05, 2008 | GE Ultrasonic 2.1 Subwoofer Computer...
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Aug 28, 2008 | Bose Acoustimass 15 System
Center and rear speakers not working
its probably ur sound card....it will work onboard..m goin thru da same problem cant find a compatible sound card...
Feb 17, 2008 | Altec Lansing VS3251 Speaker
Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Feb 11, 2008 | Velodyne CT-80 Subwoofer
5.1 Home Theatre - PC
Its due to 2.1 channel sound input from your PC. Your Laptop supports only 2.1 channel sound so all the 5 speakers cant be played at a time! You need 5.1 channel input to work all 5 speakers
Dec 07, 2007 | Bose 701 Main / Stereo Speaker
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Klipsch KL-7502-THX Speaker System Logo
330 people viewed this question
Top Klipsch Audio Players & Recorders Experts
rhodesworks
Tom Chichester
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
