Question about Kenwood VR-357
Im not getting sound from any input other than the radio what do i do?
    Brigadier General:
  • 8,546 Answers
We have no clue of what inputs you're talking about.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-357-Receivers-manual/id/480dj197/t/2/
Come back with specific questions you can't resolve.
Posted on Mar 13, 2011
No sound on AV2.Picture is excellent and cabel channels too.Its a bummer when its comes to gaming or movies because i cannot connect the colored inputs to AV1 because the video input came off the tv when i...
The RCA component cable set u are using have problems, damage the Audio connections input RCA AV connections RED WHITE cable probably have shorted out.Go to Radio Shack buy new set of RCA component cable for the replacement.
Jul 31, 2011 | Astar LTV-3201 32 in. LCD Television
Im new with the use of the record player since im tired of MP3's. i bought a Numark TTusb turntable connected everything, but the sound is low. i have to crank the volume to the max, and only get low...
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv signal..so does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Dec 30, 2010 | Numark ttUSB Turntable
I put a new stereo im my 1996 seville and it wont get power
sounds like its wired wrong .. there are three power inputs to the radio .. one is on all the time .. its for the clock only ... the second is from the panel lamp dimming circuit .. it turns on when the panel lights are on ... the third is the main power to the radio .. it is only on when the ignition is on or in accessory mode ..
Feb 19, 2010 | 1996 Cadillac Seville CA Value
I want to use my ipod in car but have no jack soket on cd to connect can i hardwire some sort of docking station to it ???. i have used fm transmitters but they all seem to crackle and im not impressed....
Will be ways cheeper buying a new car radio with an Line-input.
Check anyway if there isn't a line-input at the back. Then you could fix a jack female socket somewhere, connected to that line input.
Nov 01, 2009 | 2009 Volkswagen Tiguan
The Pioneer GM-5100T wiring help?!!
i just sent you the manual for your am everything you need to know is in there. i also have tht plug if you need it. but will only be used for high level inputs for factory radio's if you have a after market radio use your rca jacks. or if you want you could use a converter if you have a factory radio that makes speakers outputs from the radiointo rca jack that will go into the amp. the rca'sare the best way it will sound much cleaner. good luck
Sep 27, 2009 | Car Audio & Video
Im trying to hook up my wii to my surround sound and i have a denon avr-789 and im hooking it up to the aux outlet and im only getting sound no video
Connect all of your cables to your display and then connect another set of cables to your audio variable out from the television to the input you wish to get sound from on the receiver. Then make sure your tv is selected to the input you plugged the wii into, for example, Front video or Video 1 etc etc.
Jun 06, 2009 | Denon AVR-987 Receiver
HELP! Problems on my 1997 Grand Caravan P1698, P0138, P0140
you need to go over your entire wiring harness, under the hood and inside the dash. Start with the ground wire on the battery and work your way inside. It sounds like there is a loose ground wire somewhere
May 06, 2009 | 1999 Plymouth Grand Voyager
Frequency help
sounds like this radio is in 440 band and you won't be able to input any frequencies lower than 4300000.00
Apr 11, 2009 | Radio Communications
Wiring car amp up
the rem wire is for switched power from your head unit usually most after market stereos(head units) have an output for the rem wire.......if not use the power antenna wire from the back of the radio (usually blue or blue white) as for the input you need to use one or the other low or phono
Hope this helps..Good Luck!
Dec 13, 2008 | Car Audio & Video
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Kenwood VR-357 Logo
148 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
