Question about GE Spacemaker Washer and Dryer Electric Laundry Center
No heat in dryer cycles. - GE Spacemaker Washer and Dryer Electric Laundry Center
  • GE Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Aug 13, 2011
Dryer won't dry clothes in one cycle
Make sure a heating cycle is selected. Air and Fluff cycles do not use heat.
Make sure that both phases of 120 volt power are energized (total of 240 volts between the 2 phases).
Most likely the heating element is damaged, which usually means there is no heat at all. A dryer with 2 heating elements will have some heat, but not have enough, when 1 heating element stops working. A dryer with 1 heating element can partially fail and have partial heat, too.
Apr 03, 2017 | Dryers
Electric dryer..have heat on auto heat cycle, but no heat on timed cycle why?
If you have normal heat on Auto cycle, I have seen a few times that these new dryers channel the heat circuit separately through the timer for auto and timed cycle's. This isn't normal but you have a bad timer. But for any other readers this isn't a common problem generally the timer use's the same heat contact for auto and timed cycles, this is the exception.
Mar 26, 2015 | Whirlpool Dryer. 3.8 cu. ft. Electric...
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
My Maytag dryer, MDG4658AWW, will turn on heat for one cycle then heat never comes on again. Also, when using permanent cycle the heat cycle comes on once, dryer continues to run then shuts down (cooling...
heatman101
Sep 25, 2011 | Dryers
Kenmore dryer continues to heat even on air dry cycle. all cycles are high heat
My dryer model110.66832500 does the same thing ...heats on all cycles...gets overheated...what was the problem you had. what was the fix?
Sep 25, 2010 | Kenmore 84052 Dryer
Was getting one heat cycle then ignitor woud glow but no call for gas. put in new cycling thermostat, thermostat boosting heater and heat sensor. I got two heat cycles before it went cold..?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 08, 2010 | Amana DLG330RAW Gas Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Dryer flame comes on at beginning of cycle, but goes out before the cycle is completed
Based on your issue description, Gas and electric dryers have heat sources that are controlled by a cycling thermostat. This thermostat will cycle the heat on and off numerous times throughout the drying cycle. It should never keep the heat on constantly as this would cause clothes shrinkage and a chance fot a lint fire. If the dryer is drying clothes normally then you have no problem.
Aug 03, 2009 | Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
