Question about Ricoh Aficio AP3800C Laser Printer
How do i connect ap3800 to computer - Ricoh Aficio AP3800C Laser Printer
  • 34 Answers
Depending on how your network is set up, you have a couple options. If you have no network, then you can not print unless the machine is equip with a parallel print connection.
Posted on Mar 14, 2011
Tip
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Instructions
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
References
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
Regards
MultilinkEnt.
on Jun 05, 2011 | Computers & Internet
Toner not stuck well on paper and can be easely erased by hand
Sounds like you have bad toner. or fusing area not getting hot enough to fuse to paper. I would try another toner cartridge. If problem goes away. Bad cartridge.
Feb 21, 2014 | Ricoh Aficio Mp4500 Mp3500 Cl7000 Ap3850c...
WHAT DOES THE SC 38 MEAN ?? WHAT FAULT DOES THIS SERVICE CODE REFER TO?? I HAVE A LANIER 2138 COLOUR LASER PRINTER, (SAME AS RICOF AP3800 SERIES)
SC is for "Service Call". The error may be caused by a defect or an irritation of internal sensors.
Ricoh recommends to physically switch off the printer, wait for a few minutes and power on again. (Irritation by change in surrounding temperature)
If you recently replaced any movable parts inside, remove it again and reseat, many parts inside are checked by sensors for proper seating.
If this does not help, you need to call Ricoh customer service.
Feb 09, 2010 | Ricoh Aficio 3800CMF Laser Printer
HI I am trying to connect my printer via a router
You need to plug your comuter into one of the LAN Port and the Copier into another LAN port your Modem into toyr WAN port. Then you will need the IP of the router it should com along with the router Info and either be 192.168.000.1 or 192.168.0.1. add an ip spec range Isusualle use 192.168.000.120 this goes into your copier under network protacals in user tools. under the same area setup sub net mask 255.255.255.0 if you have already installed you Ricoh AP3800 Driver place the ip 192.168.000.120 again the 3rd set of numbers either .000 or .001 depending on your router. SO under start menu go to either printer and faxes or control panel right click on printer icon for ricoh AP3800 go to properties select the ports tab, Click add Port select Standared TCP ip Clickm the new port. Click next Add your IP adress for the Copier here. Click next Next window will have Generic network card so press NEXT and then Finished Close printer ports window and then click apply. This should get you printing
May 16, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
times.
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
Nov 17, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio Ap3800 service manual
i will have to know in witch country you live , cause if i give it to the wrong people in the wrong country i can get into big trouble , cause these manuals are not to be distributed .some secrets of the trade
Aug 08, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh ap3800 error code sc261
Hi there the following is taken from the service manual. Thanks J
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
Jan 14, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh ap3800
Try sending A4 or letter size to the bypass. if the same problem is risen then you will most likely have a problem with the bypass itself and nothing you have done or are doing.
The other way to check is to set a 11" x 17" in the second tray and try it that way if that goes through then there is no problem with the way you are doing things and the problem lyes with the bypass section.
Please try these and I hope they are of some help to you
Thanks J
Nov 20, 2007 | Ricoh Aficio AP3800C Laser Printer
Error Message sc376
I am pretty sure Sc376 is your Magenta not Cyan. try replacing your magenta developer unit and your magenta drum unit. If you buy them from a dealer you will have to buy all the colors not just magenta. Try Ebay first and search for supplies for your model.
Oct 17, 2007 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
48 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
