Question about LG 50PX4D 50 in. Plasma Television
My tv has audio but no image. Upon opening I have noticed there's a capacitor (d153) on the power board which is surrounded in brown residue (appears to be blown). There are also 3 empty connectors on various boards, P1, P101 and P806 are all empty. P806 appears to be a test point, but P1 and P101 look like they should be connected to something. The tv turns on and stays on everytime so I'm not entirely sure there's something wrong with the power board, but the (blown?) capacitor is worrying. Main problem is the 2 missing connectors. Any ideas?
  • marionbagget Mar 13, 2011
    The brown residue is not necessarily a blown capacitor. Adhesive is applied to the capacitors to hold them in place to be wave soldered. Over time the adhesive turns brown and spreads.
    The 'missing connectors' is because the boards are designed for many features to be added depending on the tv it's used in, country voltages/hertz and function requirements.
  • dandadog Mar 13, 2011
    Right ok, so nothing's missing. That's a relief.
    In that case, my next suspect is either the Y-sus or X-sus. Best get a voltmeter and do some prodding. Thanks.
    Problem Solver:
  • 19 Answers
Tv sound is on so not a problem with power board u may have problem with capacitor of disply or EHT or may be dry at any one capacitor
Posted on May 03, 2017
  • 298 Answers
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Posted on Dec 29, 2008
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
Posted on Oct 28, 2009
itvrepair
  • 28 Answers
SOURCE: my lg plasma tv stays on standby
is you already change the power board,is possible
your y board is out...is a big board on the left side of the tv
Posted on May 19, 2010
  • 25 Answers
SOURCE: PLASMA TV PROBLEM
The problem with this set, is defective YSUS board, to avoid future same problem, you must change the following boards: YSUS, ZSUS & Control.
Verify with LG if your serial Number is included within
lots production that were recalled by this design defect
Posted on May 28, 2010
Testimonial: "I'll try to contact LG dealers. Very hank you sir"
  • 3 Answers
SOURCE: Where can I buy a new power board for my Plasma LG
I had the same problem and opted to take the board out and replace the caps. They were all the same capacitance. Cost me $6.61 for 10 new caps (needed 9, 10 was cheaper). If you can solder, watch the capacitor videos on YouTube and give it a go.
There is a replacement for the original. You can try http://www.partstore.com/Model/LG+Electronics+Incorporated/LG+Electronics%2fZenith/50PG20.aspx?p=1&z=50&c=6e080ee60c7dbeec930c9d72f2d3d6f7&bs=Category&bd=Asc&ms=Category&md=Asc&k=&on=
and http://www.shopjimmy.com/lg-eay39190301-power-supply.htm
Good luck
Posted on Aug 20, 2010
Testimonial: "This fix worked perfectly! My TV was repaired for under $10."
How to repair LG 50PZ550-UA has no image and no audio?
Unfortunately it sounds like your power board has died.
Contact LG, or if you're comfortable with it, open up your TV and look for swollen capacitors. You could replace those, or simply replace the board that they're on.
Sep 21, 2015 | LG Televison & Video
Why does it shut down after several minutes?
Most monitor problems are caused by bad capacitors on the power supply boards inside. You can open up the monitor and look for capacitors that have bulging tops or leaking/brown residue on top. The capacitors are the pop can shaped components. capacitor Google Search
May 24, 2015 | ViewSonic Computers & Internet
120V tv accidentally connected to 240V
You most likely burned the capacitors on your power board, hopefully the overcharge did noy reach your audio visual connection bord. You will have to open the unit while it is disconnected from the power source and look for evidence of brown or black edgings around the various board components.
Smell the board if it smells like burnt plastic or wire you have blown the board or boards
If the TV is out of warranty, the cost of repair can be as high as $500+
Good Look. Ed Pinero
Feb 05, 2013 | Sony BRAVIA Televison & Video
Falt screen tv has a white screen when I turn it on,audio ok,picture comes on after about 20 minutes,any ideas?
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 18, 2012 | LG Electronics 42IN WS LCD 1920X1080...
No picture on murphy 26 in flat screen
Check with a flashlight held near the display area. If there is a movement (assuming you get the audio portion.) the issue lies with the inverter section of the power supply for the backlight.
You can open the set up and look for some bulging capacitors on the power supply board and the inverter. Replace any that have bulging or otherwise damaged tops, and those int he immediate vicinity of it. With some there might be some dark brown or black residue, bulging or not- replace those as well.
Dec 29, 2011 | Televison & Video
Turn off a few seconds after picture appears on screen
Good day!!!!
Sep 06, 2011 | Televison & Video
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
The power supply on my VW22L HDTV LCD TV does not seem to be working anymore. The red light will not turn on when it is pluged in. Any way to fix it?
Open it up and take a look at the filter capacitors. They look like little oil silos or whatever. If any of them have visible holes or seem to have a puddle of brown-ish or black residue around the bottom, then they're blown out and need to be replaced. If not, then you'll have to take them out and test them with an LCR bridge to tell if they've changed capacitance. If the capacitors are fine, then check the voltage control IC, which is normally both soldered and held in with a screw against a part of the frame or a transformer. Again, if there's a hole or any melting going on, then that's totally fried.
Jun 05, 2010 | Vizio VW22L 22 in. LCD HDTV
Auria tv model eq2288f. The power would come on but there is no image. You can turn on with remote but would have to unplug to cut the power off...
I have this same problem. The power supply board is bad, though all of the capacitors appear to be fine. No brown spots, no burnt connections, no puffy caps.
The power supply part is R0800-0810D and I can only find it on ebay for $50 plus shipping.
May 13, 2010 | Televison & Video
Power swith ic went bang!
unfortunately these boards are now obsolete, it may have damaged the bridge rectifier
Nov 06, 2007 | Samsung PS42P2S 42 in. Plasma Television
LG 50PX4D 50 in. Plasma Television Logo
46 people viewed this question
Computer Repairing
Computer Repairing
