Question about Nintendo Super Paper Mario for Wii
My son can not get past level 3..
He says he has gone through 7 doors and then turned left and can not go any further and now he is stuck as to which way he needs to go now. any help would be much appreciated. thanx Sue.
  • 8,197 Answers
Go here it will walk u through
http://guides.ign.com/guides/853822/page_10.html
Posted on Dec 15, 2008
When turning on heater in my dodge stratus its hot until you turn the vents up then it starts blowing cool what do I do
Hi Carmen, I'm AL the owner of Big As Auto Repair.
I look forward helping with your problem!
Carmen, 4 things can cause this problem. (1) The coolant level in the radiator could be low and not allowing enough coolant into the heater core. So first thing for you to do is check the coolant level. (2) A door issue inside the A/C housing can also cause this problem, if one of the doors is stuck open or broken or a cable problem or a door actuator problem can cause this. (3) The most common problem that I find is a clogged heater core. When the heater core gets clogged then the coolant coming into the core only fills enough of the core to fill hot with the low speed fan, but when you turn it to high it feels cold. (4) The other problem I have found is the Thermostat STUCK OPEN, what this does is it will not allow the coolant to get hot, and it feels colder as you drive down the road. If you need further assistance click here: Auto Repair
Feb 27, 2015 | 2004 Dodge Stratus
Schylling child's safe my son lost his combination
My sons is 34, 43. If that doesn't work, pry a corner of the door slightly open so you can see the lock on the other side of the door. You'll see 2 metal semi circles keepin it locked. Then turn right until the flat part is facing left, then turn the knob left until the 2nd semicircle's flat part faces left and the door should pop open. Hope that made sense.
Apr 20, 2013 | Schylling Combination Steel Safe
Bought a 3 year old unit for my son in law, picked it up at a storage unit. Unit panel will only turn on when the door is open. When we close the door the lights go off and it won't start. HELP
Hi
Thanks for using FixYa. This issue can be either due to a faulty door latch or door lock switch which is not engaging itself. And, if the door latch will not engage the dishwasher will sense it as open door and will not start. You'll need to check & replace the part that has gone bad with a new one. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 23, 2010 | Bosch Integra® 500 SHX46A0 Dishwasher
How do i finish world 7-2 on super mario bros? Thanks,
level 7-2 is the White Mushroom House level, so go into this level trying to collect all the Coins possible to win yourself a great prize. This level requires you to collect a minimum of 46 Coins to make the White Mushroom House appear. Wear a Frog Suit if you attempt to get this challenge done. Go right past the Nipper to use an Ice Block on the left ? Block to find a Power-Up, and then head down the next pipe. Go to the far left to collect the Coins, trigger the P-Switch, and then swim right at top speed to collect as many Coins as possibly before they revert to bricks (note that this is impossible to do without the use of a Frog Suit though).
Head back up topside to fight Nippers and Venus Fire Traps as you head right to jump into a large area where a Green Paratroopa Koopa is (kill it). Now jump up to reveal hidden Note Blocks all the way across this area before heading down the pipe on the right for a Power-Up before heading down the pipe on the left.
Swim to the pipe on the left, head topside, turn right to go across the Note Block bridge (jump straight up off the seventh from the left Note Block to reveal a hidden 1-Up Mushroom), and then continue right to go down the first pipe you see leading into the ground to fight Nippers and a Pirahna Plant as you go right to get a Power-Up.
Head back topside (using the pipe you came down in) to go right past a slew of Venus Fire Traps, a Pirahna Plant, and a Nipper to find the one short pipe that leads underground to another pipe for Mario to take. Run off to the right to find the Slot Box and finish the level!
Aug 01, 2009 | Nintendo DS Lite Console
We are stuck in Shuri Castle and can't seem to move past a door that one of the other soldiers is supposed to open. HELP!
try and explore to see if you missed a key part of the level. If that still doesnt work, although i know its painful, re-start the level. I have had other games with that problem and usually if I restart the level the game will fix itself
May 26, 2009 | Video Game Consoles & Games
Ben 10 Protector of Earth Wii.
on a wii game ben 10 im stuck on the level gold coast theater and would like to know what to do to get past it?
Apr 09, 2009 | D3 Publisher Ben 10: Protector of Earth...
Cant get past level loading screen
My son had the same problem. First of all make sure your system is not sitting on carpet as the carpet fibers will be pulled into the fan and overheat.
Save all of your trophy's on line and backup any data you wish to save.
We did a system restore which takes a while. Once this is done you be prompted to start from scratch. You will not have to set up a new user as this is saved on line.
My son is back to playing Call of Duty and all of his levels were saved as if the problem never occured.
Hope this helps
Feb 20, 2009 | Activision Call of Duty 4 Modern Warfare...
Stuck in level 7 and cant move on
When you get to the mid-level point, there are two rows of bricks and two jumping turtles. The top row question mark holds a mushroom to make you mid-size. Knock out the brick to the left of this. Then go down to the bottom row and the middle brick (directly below the above hole) holds a vine. Hit the brick to make the vine grow and climb up.
Once you are up in the clouds, jump on the mushroom. Be careful not to fall off. Ride the mushroom past the gold coin, keep going and there is a secret pipe. Jump up and go up the pipe. This will get you past world 7-6.
Aug 09, 2008 | Nintendo New Super Mario Bros. for DS
Flashing lights
That flashing pattern is consistent with a stuck carriage. Here is a copy/paste from HP concerning the 5000 series and your flashing lights.
Issue
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Close the cartridge flaps after removing the ink cartridges.
4. Turn the printer off, then on again.
5. Replace the ink cartridges.
6. Close the top access door. Issue
The Resume light continues to blink after the cartridges are released.
OR
The carriage is stuck or makes a grinding noise.
Solution
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
5. Take out the cartridges and close the top cover.
6. Reconnect the power cord to the back of the printer. Plug the power cord to the wall outlet.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Oct 23, 2007 | HP DeskJet 5550 InkJet Printer
Nintendo Super Paper Mario for Wii Logo
97 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
