Question about Hotpoint HDA3520ZBB Dishwasher
My FDW80 hotpoint dishwasher has stopped releasing the tablet. The door won't pop open. Any ideas???
I have just had this fault. The control solenoid had burnt out but unfortunately that led to the component that controls it blowing out, and typically the component number has been blown off so I can't identify it. I'm still trying to identify the component or get a circuit diagram.
Posted on Oct 14, 2012
  • Hotpoint Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Mar 14, 2011
Hotpoint FDW60 DishwasherTablet does not dissolve
our HOTPOINT FDW60 is not working right?
the tablet is not disolving inside right how will i fix it?
Feb 07, 2013 | Hotpoint 24 in. FDW60 Free-standing...
I have got a hotpoint BFI62. The detergent flap does not open during cycle. Have replaced the detergent unit with a new one , but still have the same problem. Any suggestions as to the problem would be...
I have same problem - the flap was designed for powder, it jams with tablets. My current solution is to run it when I'm around, and when I hear it 'clunk' to release the soap, I open the door and help it!
Jun 12, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Door does not lock shut but machine still works. Is it easy to repair?
Exactly the same happened to our Hotpoint FWD70. The spring that holds the door latch in place has snapped. I removed all screws out of the door to find the spring and the metal rod it hooks onto and bend another hook into it (I didn't have a replacement spring), put it back together and the door works fine, although for some reason the dishwasher tablet doesn't release now!!
May 19, 2009 | Hotpoint Ultima WF865 Front Load Washer
Fault Code AL03 in an FDW80 dishwasher
Al03 stands for problems with the drainage either ur pump is blocked or has just stopped working so not enough pressure to drain out water during cycle
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW80 dishwasher showinmg an AL10 fault.
Thank you for your quick reply.
Our solution - Added salt and rinse agent (I think it was probably the salt). All seems OK. No fault warnings showing.
Nov 06, 2008 | Hotpoint Dishwashers
Hotpoint fdw80 dishwasher
Faulty heating element. Had the same error and got Hotpoint to replace the element. Error was also confirmed by their engineer.
Apr 13, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint FDW80( A10 Appears ondisplay half way through cycle)
here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water
  • Hope this helps?
    Jan 06, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    Dishwasher tablet not releasing
    sounds like the dispenser solenoid is faulty you will need to replace the whole unit, this involves removing the door panel.
    Jun 08, 2007 | Indesit 24 in. DE73 Evolution...
    Dishwashers Logo
    613 people viewed this question
    Top Hotpoint Dishwashers Experts
    AcmeUK
    Level 1 Expert
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
