Question about Dishwashers
No water supply to dishwasher ,water is on and filter is clean but i still can't get any water through
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Mar 14, 2011
Are there intake filter screens on the GU1500XTL B?
I have never heard of a water filter for a dishwasher since the water entering your house is clean and filtered and potable. If the water supply line for your dishwasher is clogged you have a different problem where in you must clear it to allow sufficient flow for the machine to fill. If it is restricted it will most likely take longer to fill but it will still operate. If the filler is on a timer then you will not be getting enough water into the machine and must restore adequate flow for it to operate. There is no need to filter water into your dishwasher. People who have water supply problems will get water conditioners for hard water issues and whole house filters for sediment problems. I would get Culligan to take responsibility and fix the problem if they caused it.
Mar 11, 2014 | Whirlpool 24 in. GU2500 XTP Built-in...
Dirty Dishes
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Sep 28, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
How do I change or clean the filter on my Lamona 8362 dishwasher ? I do not appear to have been given a user manual Thanks
  • 1 Wait until the dishwasher has completely cooled after use before attempting to clean the filter. Turn the dishwasher off and unplug it from the power supply.
  • 2 Remove the lower dish racks and locate the filter compartment on the bottom of the dishwasher.
  • 3 Unscrew the filter housing and gently pull to lift out the filter.
  • 4 Use a few drops of dishwashing liquid, warm water and a soft-bristled brush to clean the filter and the filter housing.
  • 5 Dry the filter and the housing and reassemble them. Reposition them in the bottom of the dishwasher and turn until locked into place. Replace the racks and close the dishwasher door. Plug back in to the local power supply.
  • Jul 07, 2011 | Dishwashers
    The dishwasher has stopped working,there is a water supply & power supply ,cannot see any obivious problem.Bill England
    The problem is resolved, i disconnected the water & electricity supplies, cleaned the filters and all moving parts, reconnected elec & water supplies switched back on and the disher worked perfectly and has since.
    Dec 07, 2009 | Bosch 24 in. SGS43C12 Classixx...
    Keeps alarmimg 1E on my Lg Dishwasher
    Inlet water error 1E
    Not reached to the normal water level in spite of 10 min. water supply
    The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
    Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
    Sep 24, 2009 | LG Dishwashers
    KitchenAid KUDP01DLWH6 dishwasher filter clog
    Follow the main water supply line. It goes to a solenoid valve which is normally located front left side under the dishwasher.
    1. Turn off the main circuit breaker for the dishwasher.
    2. Turn off Water supply to the dishwasher.
    3. Remove lower front panel.
    4. Remove Water supply line from solenoid.
    5. remover wire connections from solenoid.
    6. Remove 2 mounting screws from solenoid.
    7. Take solenoid valve out.
    8. Look inside the valve where the water supply line was connect to, You will be able to see the filter. it is just a screen and you can easily clean it.
    Good Luck
    Jun 27, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
    Dishwasher suddenly doesn't clean well-doesn't empty soap disp
    Hi
    Tools required:
    Adjustable wrench
    Multi-Screwdriver
    Pliers
    Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
    Thanks
    Rylee
    Mar 25, 2009 | Maytag MDB5100A Dishwasher
    Silverware and dishes not getting clean, leaving grit on dishes
    It cleans poorly If your dishwasher is cleaning poorly, check these:
    Water-inlet valve
    Internal filters
    Drain valve
    Spray arms
    Water temperature
    Detergent cup
    Tools required:
    Adjustable wrench
    Multi-Screwdriver
    Pliers
    Mar 03, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
    I have a brand new Miele dishwasher which has worked grate since it was installed 2 weeks ago. It keeps shutting itself off & indicates an F13 fault. I looked in the manual, see that water is going in...
    On my Miele 1220 dishwasher, the inlet filter is inside the inlet hose connector, where it screws onto the water supply. To clean it:
    1. Turn off the stopcock. 2. Unscrew the inlet hose. 3. Remove the black rubber seal gently with a screwdriver. 4. Use pliers to remove the inlet filter. 5. Clean the filter under running water. 6. Replace the filter and seal. 7. Reconnect the inlet hose to the water supply, making sure the screw does not thread. 8. Turn on the stopcock slowly to check for any leaks.
    Dec 06, 2008 | Dishwashers
    Indesit IDL 530 Dishwasher
    Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
    Apr 12, 2008 | Indesit Dishwashers
    Dishwashers Logo
    Top Dishwashers Experts
    Owen Barnes
