Question about Braun FlavorSelect KF 180 Coffee Maker
My KF 180, Type 3115 Braun Coffee Maker stopped working, no heat, no purking but red light is on. I'm trying to open the bottom cover, have removed the centre screw but still can't get past the clips. I suspect a burnt out element. How can I open it? Thanks, George.
I have the same problem and even though I was able to disassemble the unit + get to the heating element, I fear I won't ever find a replacement part. Element is def bad; checked w/ohm meter across element - OPEN.
Like everything else we buy, coffee makers are throwaways when they fail so no one sells repair parts.
SAD!
Posted on Nov 17, 2011
I have a Braun KF600 thatI love. 2 days ago, it just stopped working. The on/off light is lit, so we have power. Water doesn't start to heat. No gurgling sound and water doesn't drip., therefore no...
Sounds like it could be a bad heating element, you could try to find a replacement but it would be pretty pie in the sky.
This is the cheapest replacement that I could find.
http://compare.ebay.com/like/140541415123?var=lv<yp=AllFixedPriceItemTypes&var=sbar&rvr_id=229795861013&crlp=1_263602_309572&UA=L*F%3F&GUID=bca9cdf912f0a0aa17765ae6ffe0749e&itemid=140541415123&ff4=263602_309572
May 04, 2011 | Braun Impression KF 600 Coffee Maker
I push the start button (the one with the red light) and the light turns on, but then nothing happens. (Yes, I had water in the tank and coffee in the filter part.) Usually, I push the button, the light...
Sounds like there an issue with the heating element. When the element goes bad it wont pull any water from the tank nor will it heat the water sending it up through the shower head and onto the beans. Unfortunately, since Braun has discontinued ALL kitchen appliances here in the US many of the parts are obsolete including the heating element for this machine.
Mar 29, 2011 | Braun FlavorSelect KF 180 Coffee Maker
Any one know how to set the shut off timer on the KF180 Braun coffee maker
Hold down on/off button until it blinks. Display should read 3:59. Adjust with "h" & "m" buttons to set auto shut off duration.
Feb 25, 2011 | Braun FlavorSelect KF 180 Coffee Maker
Braun coffee maker starts brewing, then stops after a few seconds
ijustam1
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Jan 22, 2009 | Braun FlavorSelect KF 180 Coffee Maker
Braun Coffeemaker Programming
to prgram the automatic operation, press the automatic buton until the green pilot light begins to flash. The time "12:00" or the previously programmed time appears on the display. When the green pilot light begins to flash, release the button and press the hour and minute buttons until the correct shows; ensure the hours are am or pm. After programming is completed, the green pilot light will go off after 5 seconds.
Dec 08, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Braun Coffee Maker Type 4093
it sounds like the hole at the bottom of the waqter tank is clogged. the fact that it is hot means the electrical parts are all working.
it should be an easy fix
May 18, 2008 | Braun Aromaster KF 400 Coffee Maker
Braun FlavorSelect KF 180 Coffee Maker Logo
613 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
