Question about Maytag Washing Machines
My Maytag washer Model# LAT8306AAE will only fill on the regular cycle and perm. press. the delicate cycle works fine. Thanks
  • 3 more comments
  • Terry Schmidt Mar 14, 2011
    sorry , the only thing it will do is fill on those cycles, the timer is moving. The delicate cycle works fine. I ran water only through all the cycles it worked as soon as I put items in the regular and perm press cycles would only fill . I turned timer to delicate rinse it would drain and complete that cycle. The timer advances in all the cycles.
    The timer advances in all cycles . It will only fill in regular
    Keith, email said you gave me a fix for my problem as of this message I haven't received one or I am not looking in the right place. please reply.
  • 4,323 Answers
Hi
If you have already checked part#7 water inlet valve (in this diagram) and it is fine then the issue is with part#13 water level switch (in this diagram) that should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 14, 2011
    Guru:
  • 262 Answers
Hello....My name is Keith.....Please give me one moment while I bring up the parts drawings, and then I will start to address the issue.
Thank You....
Posted on Mar 13, 2011
  • 1 more comment
  • Keith Drake
    Keith Drake Mar 13, 2011
    Just need clarification on some things....
    You are stating that the unit will only fill on regular cycle and perm.press cycle as in that is all it will do?
    Or thoses are the only cycles that it fills on.
  • Keith Drake
    Will timer advance in the two cycles that you are saying only fill?
    Try both cycles....
    If the timer is advancing in the above mentioned cycles....will the machine drain?
  • Keith Drake
    Keith Drake Mar 14, 2011
    This is a strange one....
    May be looking at two seperate issues.
    can you use a volt meter?
    If yes you will need to check timer to motor
    here is a link to your washers wiring schemnatic
    Click on the link http://www.searspartsdirect.com/partsdir...
    Ensure you are getting 120v in all cycles to motor....if not it will be a timer issue....(I'm leaning this way) if you are ....maybe motor windings....but I seriously doubt it.
    Please post results
    Keith
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
Whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Feb 11, 2010 | Washing Machines
Explanation of Wash Cycles
Sorry but you only have the one speed on this particular brand. Perm and short are just less time. The best thing to do is always use large water setting and less delicates in the load on a short cycle to compensate for the speed and protect your delicate fabrics.
Jan 27, 2010 | Whirlpool ET8CHEXSQ Dryer
Maytag PAV2300AWW, ONLY WORKS ON REGULAR CYCLE. ON DELICATE CYCLE CLICKING NOISE LIKE SWITCH OFF AND ON AND AGITATOR WILL MOVE SLIGHTLY WHEN CLICKS. MY SON HAD IT ON A WHILE BACK ON THE DELICATE CYCLE AND...
Your timer is bad on that cycle. It is okay to use on regular cycle, but I would not use it on the delicate cycle, or will you burn up your timer. You should be home when using this, so if it does act up you can catch it.
Dec 01, 2009 | Maytag PAV2300 Top Load Washer
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Maytag Top Loader won't work on Regular Cycle
I suspect bad motor windings. it has enough power to run delicate but not other cycles?
Nov 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag washer-n-dryer(stacked). When the washing machine is filling in the wash cycle of the delicate or the permanent press cycles, it will not stop filler the drum with water. The washing...
it sounds like your water inlet valve is bad,change it,also try your washer on another water level like small load or med load and see if it cuts off,it might also be your water level switch,hope this helps,thanks-mike
Jun 02, 2008 | Maytag Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
