Question about Home
I installed a Mira Galena electric shower 2.5 years ago. It has worked perfectly until recently. Now it works for approx 1 minute then stops dead. The water cuts off but the power light remains on. I have changed the thermal switch and the 2 micro switches but the problem is still there.
dennymulford
  • 1055 Answers
SOURCE: mira thermastatic shower problem,pressure&temprature.
you mixing valve may be going bad,do you have hard water? you may just need too take it apart and clean it
Posted on Mar 07, 2009
PrettyEasyGo
SOURCE: No electric power when plugged in and turn on switch/cuisinart DC
tried ALL solutions on this & other blogs-even to point of CAREFULLY drilling out plastic to get bit-holder down to the 'MAGIC FASTENER' level and then trying: #10 TORX; ## 7-10 TORX; 'security TORX(with hole in middle) & several other 'secret bits'---ALL TO NO AVAIL !!!!! :0(
then, in SHEER DESPERATION, called Cuisinart @ 800-726-0190 [this is on SAT morning 0915 on 3/28/09] got VERY HELPFUL/KIND/PATIENT rep who was ready to do the " $10 +old one AND $10 for new one" routine, when she said: "Did you try re-plugging into wall socket after 1 hour? That's the re-set time" !!! while she was on the line (they work 'til 1730 EDT on SAT/SUN & 'til 1100 M-F !!!) wife tried this highly-technical/super-secret solution -and- IT #$%^*'ING WORKED !!!!!! ;0) I'm sitting here drinking coffee outta it and posting this solution.
Posted on Mar 28, 2009
SOURCE: TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Posted on Mar 09, 2010
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: Toyo Aircon. Starts perfectly. Runs
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
My mira elite 2 shower is leaking,The flow and tempt is ok. but the leak has got worse and it is cold water the leak is not from the hose that is connected to the shower head. It only leak when its on
Please use plumbers white tape wrapped in a clockwise diection. Tighten and let us know Geraldine. Thank you and send us a picture if you can. Best of luck leave feedback
Jul 13, 2016 | Home
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
Got mira discovery mixer shower. wont get hot just luke warm or cold. taps in rest of house ok? Had it off the wall recently to tile behind it but apart from that been great for 6 years. any ideas?
There should be a hot water limiter behind the knob on the shower - shingle handle, undo the handle and move the adjustment to allow more hot water. Not familiar with mira discovery mixer
Feb 03, 2013 | Home
Mira sport electric shower losing heat
It sounds like the heating element is going bad, needs replaced.
Dec 01, 2012 | Plumbing
My mira sport is approx 6 years old .when switched on its hot for only 1 minute then goes cold
The Mira 416.41 - Thermal switch has gone bad this link shows where it is and you can order from here if you want.
http://www.showerspares.com/products/spare_parts/mira_sport_108kw
Mar 04, 2011 | Home
Mira thermastatic shower problem,pressure&temprature.
Mar 06, 2009 | Plumbing
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Triton Electric Shower Temperature too hot
You could have mineral deposits on the temperature probe inside of the unit. If you remove the heater and purchase a bottle of lime and scale remover (lime away) to put inside of it. Let the unit sit full of water and chemicals for 24 hours. Flush out the unit to remove any residue. You may see the water is brown if you have a lot of buildup. Reconnect unit and test your settings. If this doesn't work, install a anti-scalding device, available at a plumbing supply store.
Oct 22, 2008 | Home
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
