Question about Kenmore Dishwashers
We have a Kenmore Elite Dishwasher Stock No. 13412K Type No. 577-0 Serial: FW391XXXX 665.13412K701 or 66513412K701 Recently I noticed after I open the door to empty the dishwasher, I'll find a little pool of water on my hardwood floor. The water appears to be coming out of the vent in the door. Is this a common problem, and should I be able to fix it myself?
5 Suggested Answers
SOURCE: Kenmore Elite Dishwasher 16939
I have the same model dishwasher with same problem. The gasket first came loose just after my warranty expired. The stainless steel and heat don't make for a good combination with the glue that holds the gasket in. My husband works with caulk and the like. He found a clear gel of some sort to get everything to adhere. It's had to be reapplied. I just make a habit of making sure the gasket is seated in its track and watching if dishes on top rack catch the gasket when I pull rack out.
See www.repairclinic.com, item #1065754, White silicone adhesive, specially formulated for use in the dishwasher to adhere tine tips & door gaskets. It's an accessory for this dishwasher. I don't know if Sears Parts Direct offers it. Sometimes their price is lower.
From above website it costs $14.55
Posted on Jan 08, 2009
scottowa
  • 87 Answers
SOURCE: Have power to the control panel but the thing don't work????
I take it nothing lights up at all? In the 665 it is very common for the thermal fuse to go out. It should be on the control panel with 2 wires coming out of it with spade terminals. Disconnect that and see if there is continuity
Posted on May 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a kenmore elite dishwasher 577-9 17262402.
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
nabbot
SOURCE: Drying cycle vent fan is noisy. How can I fix it
I had the same issue but mine is an inbuilt unit. I removed the 4 screws for the front main facia panel which was then removed. Following this I removed the 6 screws that hold the plastic control cover in place and then the three screws (1 top centre and 1 on left and right) that holds the control plate which I then gentrly lowered.
I then used a flat blade screw driver to turn the inside fan cover anti clockwise about 45 degrees which allows the fan module to be removed. Then disconnected the drain pipe at the fan module only and power and control cables.
I then blew the gunk out of the fan module and gave this a good wash through with hot water to ensure it was clean and then dryed with paper towel. I then also blew out the drain pipe. The remaining gunk was blown into the interior of the dish washer out a vent just below the rinse aid unit.
If I need to do this again then I would have removed both ends of the pipe and washed this through with hot soapy water to make sure it was clean.
To reassemble do the reverse process. Assistance will probably be required to reassemble the front main facia panel as one person would need two hands to hold in place and another to locate and start the screws. A couple of clamps could over come this.
Posted on Jan 05, 2012
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66517483300/0582/0130000?pathTaken=&prst=0&shdMod=66517483300
And your manual.
http://www.managemylife.com/mmh/owner_manuals/10240/KENMORE-Dishwasher-L0308215?brand_name_search=665.17483300
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
Apr 30, 2009 | Dishwashers
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
Leaking
thats your in let vavle ,,mostly came lose,,open toe pansl,,and thighten connect,,always turn off breaker,,most dishwasher are not grounded in places...
Jan 15, 2009 | Dishwashers
Need the model number of the Kenmore Elite dishwasher 1378(2)
The model number will be something like 110.123456
Dec 25, 2008 | Kenmore 13789 / 13782 Dishwasher
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Dishwashers Logo
103 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
