Question about Poulan P4018WT Wild Thing 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw
Having trouble putting on new chain.have no manual.the 2 mounting holes in bar what are they for
    Novelist:
  • 144 Answers
There should be some bolts that allow you to tighten the bar, and a slot that allows the bar to slide when you loosen the bolts.
Also, there should be some kind of adjusting screw that allows you to tighten the chain. To remove the old chain and install the new chain, you'll need to completely back off any tension on the adjuster, allowing the bar to move TOWARD the chain saw.
You should keep the chain oiled, and whenever it stretches, even a little, you should adjust the chain according to the owners manual too keep it at the right tension.
The two mounting slots are usually aligned with something that will keep the chain bar straight; such as a bolt or perhaps a pin in the motor assembly.
Posted on Mar 13, 2011
I put the bar & chain on, the three hole line up easily but how do i get the brake back on the clutch?
The proper sequence to installing the chain should be to first ensure the brake is in the 'unlocked' position then loosen the chain adjustment screw, slip the chain over the back of the sprocket, align the chain with the bar, slip the bar onto the bar mounting studs ensuring the adjustment pin slips into the appropriate hole in the bar. Then slip the outer chain cover over the bar studs, elevate the front end of the bar and tighten the bar mounting nuts to 'snug'. Adjust the chain tension to the desired setting ensuring the front of the guide bar remains elevated, then tighten the nuts to secure the bar.
Remember to unlock the brake BEFORE removing the bar and chain because it is so much easier to unlock it mounted on the saw if yours is the design that comes off with the cover. If yours stays on the block of the saw and the blade is removed you have to secure the saw on the workbench or on the ground and unlock the brake just like you would with the bar installed.
Keeping the front of the bar elevated during assembly and adjustment of the chain will keep the chain tension correct for a much longer period. I hope this helps.
Mar 03, 2015 | Garden
Barandchainmantaniceon a290
It sounds like the small hole in your bar that carries the oil to the chain is blocked. Start by removing the bar and chain from the saw. Clean around the chain mounting area on the motor block. Take the chain off the bar and clear out the groove in the bar working from the end with the sprocket wheel to the mounting on the motor block. Use a fine stiff 'poker' that goes into the groove and clear all the rubbish out. If possible also blow it out with compressed air. Near the mounting end you should see a small hole on that goes from the outside of the bar to the bottom of the groove. If it is blocked clear it out. Make sure the sprocket turns freely and remount the bar and chain. If you still have the problem then the bar must be wrong for the saw - it could be a Husky bar that has the hole in a slightly different place!
Jan 30, 2014 | Stihl Garden
Husqvarna 455 rancher, chain getting too loose to tighten after one days use age. Bar oil topped off with every fill up of gas. Bar cleaned in the groove, etc. New chain. The bar will no longer adjust to...
indicates incorrect length chain in use
the adjustment slots should be about 1/3 when fitted moving close to 1/2 when adjusted
the correct adjustment is when the chain in the center of the bar is lifted up the bottom segments of the chain are still in the bar groove
make sure that the oiler hole is not blocked from saw dust and chips
Aug 08, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
Need instructions on how to replace a chain on Homelite chainsaw
Remove the drive end side cover after releasing the chain brake if it exists and removing the mounting nuts. The bar should slide back and allow the old chain to be removed. Take out the bar and clean it's oil passages including the two small channels that go out to the chain groove. Clean the entire chain groove. Clean the motor case side where the bar fits to. Run the motor for a few moments to see if oil oozes out of the side port. If ok, reinstall the bar and push back. Thread the new chain over the sprocket, then work it over the bar making sure the bottom run of chain cuts toward you. Pull the bar outward. Replace the cleaned cover making sure the adjustment tang drops into one of the large holes in the bar--you may have to back out the adjustment screw several turns. Replace the mounting nuts finger tight and adjust the chain until it pulls the lower run of chain up to the bar, yet you can still pull the chain by hand. Tighten the bar nuts firmly and recheck the chain tension. Check for proper oiling by running the saw tip near cardboard for several moments--it should leave a thin line of oil on the cardboard. Hope this helps!
Jun 18, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
The chain came off. How do I put it back on? I do not have a user manual for it.
Remove the drive end cover by removing the large nuts/bolts. Remove the bar and run the motor for a few moments, which should reveal oil oozing out of a side port where the bar fits. If ok, then spread out the chain so that it can be inspected for any damage that may have occurred. Check the bar itself for any damage. Clean all of the parts including the oil passages in the drive end of the bar and the entire chain groove. If there is a sprocket on the bar end, make sure it turns freely. Check the drive sprocket teeth for extreme wear or damage. If all ok, insert the bar and push it back toward the motor. Then thread the chain over the sprocket, then over the bar. Pull the bar out, replace the cover with mounting hardware finger tight and make sure the adjustment 'tang' fits into one of the large holes in the bar. The chain teeth need to cut toward you on the lower run of chain. Adjust the chain until the chain pulls up to the bar, but can be pulled by hand. Tighten the mounting hardware and recheck chain tension. Make sure the chain is properly sharpened. Hope this helps!
Jun 16, 2010 | Remington Polesaw Wizard
Can i download a manual for the homelite 33cc chainsaw to get instructions for how to put a new chain on
Release the chain brake. Back off the chain adjustment screw several turns and remove the two large cover nuts. Remove the drive cover, then pull the bar back toward you. This will allow the old chain to be removed. Remove the bar and clean the entire area where the bar mounted. Check the outside edges of the chain groove area for any flaring out of the bar metal due to wear. Use a flat file to cut off this flaring edge (at about 45 degrees) so that nothing projects beyond the bar vertical surface on both sides. Turn the bar upside down to even the wear in the chain groove. Clean the oil holes in the bar end including the small channels that bring oil from large holes out to the chain groove on each side and clean the entire chain groove. Insert the bar, then feed the new chain with the teeth on the lower run cutting toward you, onto the sprocket, then work it over the entire bar and pull the bar out as far as it will go. Install the cover (which has been cleaned too) and run the nuts on finger tight (make sure the adjustment tang dropped into a large hole at the bar rear). Turn the adjustment screw CW until the chain ceases to droop from the lower bar, but the chain can still be pulled by hand. Tighten the large nuts firmly and recheck chain tension--if ok, start the engine and hold the bar tip near a piece of cardboard while the engine runs at speed for several moments--you should get a thin line of oil thrown off onto the cardboard. Hope this helps!
Jun 11, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
How do I put chain back on the Wen 14'' chain saw
Remove the chain drive side plate and remove the bar. Clean the drive area and inspect the drive sprocket for excessive wear. Run the motor for a short time to make sure that oil is being pumped out to the bar--is should just ooze out. Clean the bar chain groove and clean the oil holes at the drive end of the bar--especially the two small holes that go from the large oil holes out to the chain groove. Back off the chain adjustment screw several turns, then fit the chain over the sprocket (teeth cut toward you on the bottom) and then insert the bar into the chain and push the bar out till the chain is fairly tight. Apply the side cover and make sure the adjustment tang drops into the large hole at the rear of the bar. Install the mounting nut(s) to hold the plate and bar together. When run-up finger tight, turn the adjustment screw CW until the chain becomes tight enough that it doesn't droop from the bar, yet can be be turned by hand. Tighten the side cover nut(s) and recheck tension. If ok, run the saw for a few moments with the bar tip near some cardboard--it should throw off a thin line of oil. Keep the chain properly sharpened to reduce the chance of this occurring again. Hope this helps!
Apr 29, 2010 | Garden
Garage door opener, how does T bar affix to motor assembly (chain drive), I took it apart 3 weeks ago to repair the worm drive, am missing cap for chain (not worried), and the T-bar doesn't seem to attach...
The t-bar has two holes in the end of the bar off set from each other. The chain must be slack to get to align up to the motor head. There are two holes in the top of the motor head, I believe they are 1/2 inch drive black tempered screws. If you lost these two bolts make sure the replacement ones are not too long and do not exceed 5/8" long and will have to have a lock nut on it. Then tension the chain and set limits. Thanks BB
Feb 24, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
How do i put a chain on the chainsaw
Set out the chainsaw parts in front of you. Make sure the chain is facing the right way to cut wood; the teeth should be facing away from you when you are holding the chainsaw.
Secure the chain around the sprocket (a cog-type part found near the chain tension nipple) and align it along the grooves of the bar. You will see a hole for the chain-tension nipple on the end of the bar. Line these up so the nipple fits in the hole on the bar. Pull the chain to tighten it, using the screw to achieve the desired tension
Place the cover plate back on top of the bar and line up the cover-plate housing screws with their corresponding screw holes
Screw the cover-plate housing screws back in and tighten. Test the chain to make sure it spins freely when pulled.
Check the chain to make sure you can lift it about 1/4 inch, so it isn't too tight to spin while cutting wood
Dec 21, 2009 | Televison & Video
Chainsaw Bar Lube Oil Leaking
A new mounting bar would solve this issue. On that mounting bar there is a little piece that allows oil to drop onto the bar when you call for it or if this is a electric bar oil chain saw. Then it tracks when it needs to open.
Feb 14, 2009 | Garden
Poulan P4018WT Wild Thing 18Inch 40cc 2Cycle Gas Powered Easy Start Chain Saw Logo
106 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
