Question about Sport & Outdoor - Others
I lost directions for my farberware kitchen timer. it is battery operated,has a digital display and 4 buttons.(one green ,one red and two black buttons..) i cannot reset the time. if you can tell me the internet location for a manual i would appreciate it
I recently bought one. The instructions are on the packaging.
To switch from timer mode to clock mode, press STOP and START together.
To set the clock, press START and hold for 5 seconds until the whole display flashes. Press HOUR to set the hour. Press MINUTE to set the minutes. Press START to start the clock.
Posted on Jul 22, 2011
Cannot get new digitical timer to work have 2 black wires in wall box but new timer has black, blue,green,red, and white
Red wire is used for 3-way only... cap off for single pole
White is neutral, black is hot, blue goes to load, green is ground
Copy following link for wiring your timer:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If box does NOT have white wires twisted together and covered with wire nut: then suggest to buy Ei600 or ST01 battery operated timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ST01C
Gene
Apr 18, 2014 | Intermatic Hardware & Accessories
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
WOODS 59018 TIMER WIREING CORRECT INSTALLED WITH POWER OFF NETURAL GROUND UP TO CODE LOAD /LINE PROPER.NEW OUT OF BOX WON'T RESET. STEP 1 LAMPS LOAD SIDE GOOD. RETIRED CONSTRUCTION ELECTRICIAN
I don't have answer for defective timer. Buy another timer if everything below checks out:
59018 7-day timer has limited 1 year warranty, and appears to be made by Tork
Timer is for 120Volt single-pole only.
Rated for 1000 watt tungsten, 8A ballast, 1/4 HP
Push reset button with toothpick > not necessary to press-and-hold other button to accomplish reset.
After reset, 12:00 am Monday should display.
Programs are deleted. Reprogram timer.
To check, change and delete specific programming, press PROG key until selected program displays, and then set new programming >>> or press-and-hold MODE button and press PROG button again to delete selected program.
Timer has non-replaceable 30-day carryover battery and does not lose programming after power outage, and will retain programs until battery is depleted.
Review wiring:
Hot to timer black.
Neutral to timer white.
Load to timer red.
Ground to timer green.
Lights will blink if timer red and timer white are connected to load together.
Timer will not function if timer black and red wires are reversed. Display will not show.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Aug 07, 2011 | Woods InWall 7 Day Digital Programmable...
2 switch system. 2 black wires and 1 red wire in the switch. I have hooked up black wire from the switch to the red wire in the box. green wire from switch to black wire from the box and red wire from the...
You posted under ST01C and are wiring timer to replace 3-way switch.
Open following link for specific illustrations:
http://waterheatertimer.org/ST01C-program.html#ST01C
http://waterheatertimer.org/pdf/ST01C-explanation.rtf
1) The timer replaces one of the 3-way switches. The other 3-way switch remains, but must be rewired.
2) The timer must replace the 3-way switch that receives power from breaker box. It cannot replace the other 3-way switch. This is because the timer Black wire must always receive power.
3) The timer blue wire must connect to Load (light)
4) The ST01C red wire is only used when wiring for 3-way.
5) When the red wire and blue wire are connected together, they reverse the timer program. When timer red and blue are disconnected, the timer resumes programming. Connecting and disconnecting the red and blue wires is how the timer mimics 3-way operation.
6) The remaining 3-way switch must be wired so it will connect and disconnect the red and blue timer wires. So the remaining 3-way switch has to be rewired to meet specific timer wiring.
Jul 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a 3 gang box: a is for hall light switch
Timer is not identified. Battery-operate timers wire differently than timers that require neutral wire.
For 4-wire battery-operated Intermatic EJ500, ST01C, and Ei600, Ei400 wiring:
For 4-wire Intermatic Ei200 series, KM-series, Ei500 that require neutral wire
http://waterheatertimer.org/Programmable.html#wire
Add a comment with model number for more specific information
Jun 19, 2011 | RTO Intermatic Digital 7 Day Wall Switch...
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
When I press the timer to go on my three outdoor lights go on and off, timer clicks that way too
Timer is wired incorrectly.
1) If you have battery-operated Intermatic EJ500 or ST01C, with red, blue, black and green wires:
Then red wire is where blue wire should go. Swap blue and red wire.
2) If you have Aube battery-operated timer, add a comment and say if you are replacing single-pole or 3-way switch. And say where each wire is so far.
3) If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Heres how to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Dec 11, 2010 | Woods Hardware & Accessories
Installing replacement for neighbour and cannot get lights to work. Single switch running 6 flood lights(each 60w) with 2 burned out. Have power to switch as can get standard switch to work. This is...
If I understand correctly you have standard on-off situation for exterior lights. Load is 360 Watt, well within capacity of all in-wall timers.
You have identified the hot wire.
You have confirmed that load works, and that electricity is ON.
Regular on-off switch works fine.
Now the information is a bit fuzzy.
You are installing a timer to control this load?
You do not identify timer.
So I will jump into the shark waters and ASSUME ...
That your timer has 4 wires?
A) Timer is battery operated Intermatic ST01C or EJ500 with red, blue, black, green.
Red is capped off.
Green goes to ground.
Black goes to hot from breaker.
Blue goes to Load.
Click on-off button, if timer does not operate, reverse blue and black.
If lights click on-off, then you put red wire where blue wire should be
B) Timer does not have battery and is Tork, GE, Intermatic, Woods, Utilitec, Westek and has red, black, white and green wires.
Here's what to do:
Two switch wires connect to red and black in any order right now.
In back of electric box are white wires twisted together and covered with wire nut. These are neutral wires. Timer white wire connects to the neutrals. This will power the internal clock motor.
If box does not have neutrals, the timer white wire connects to bare ground along with green wire.
Click manual override button, if lights do not turn on, then reverse red and black wires.
Why does you neighbor's timer not last very long?
I don't know.
If timer has battery and timer exposed to cold temperatures, then battery lasts about a month.
If timer has no battery, you have to send me the model number and let me look into it.
Use a circuit analyzer on receptacle on same breaker and see if anything shows that might interfere with electronics.
Dec 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Lights turn off and on manually and can program time, date, year, etc. but unit will not operate on and off automatically with the sun set or rise.
You posted question under ST01C timer.
ST01C is battery operated.
It has black blue red and green wires
I have tested this timer a little bit
If you have your blue and black wires reversed, then it will produce the symptoms you describe.
ST01C will not operate programs if blue and black wires are reversed
Remember the red wire is capped off in the ST01C
http://waterheatertimer.org/Intermatic-st01c.pdf
ST01C programming:
ST01C instructions are long and complicated
When I have this kind of instruction manual, I start writing out the parts that seem critical
I think if you try this technique, it will work as long as timer is not defective.
What if you have another brand timer?
Timers without a battery have to wired correctly or things will not work
These timers usually have black white red and green
If the red and black are reversed, you might not get power to the display
I have not tested these timers thoroughly yet
Review your wiring with all in-wall and plug-in timers
Write out the instructions
If this information was not specific enough, please re-post your question showing brand and model number so the answer can be more specific
Oct 19, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Sport & Outdoor - Others Logo
1,882 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
