Question about Kenmore Dishwashers
I have a Kenmore ultra wash dishwasher model 665.17604 that will not drain. Any suggestions?
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Mar 14, 2011
My Kenmore Ultra Wash Dishwasher Model#665.13842K600 doesn't fully drain a the end of the cycle. There is always dirty water left in the bottom of the unit.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
heatman101
Oct 02, 2010 | Dishwashers
I have a Kenmore ultra wash model 665, stock# 15951. When the tub starts to fill the water runs out the drain.
This means there is either an air gap in the drain hose or the drain hose loop is less than 32" high preventing back flow
Sep 18, 2010 | Kenmore 24 in. 15159 Built-in Dishwasher
Kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Oct 25, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash III Dishwasher will not drain properly
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Dec 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Will not drain
can you see the check valve? may have something blocking it closed.
Oct 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
the odd shaped screws are called trox screws and can get a set of drivers any where also pull the hose off the sink connection and check it there the main motor reverses and acts as the drain pump if you recently installed it to a garbage disposal make sure you knocked the plug out where the dishwasher connects if not check the hole there i found a olive pit in one one day now when you go to by the trox drivers and a bunch of things are using them now days get the set in the metal case that fold out like a pocket knife if you know what i mean and the drain hose must come up 20 inches and then loop to the sink drain so let me know what you find and if i can help further
Mar 18, 2008 | Dishwashers
Kenmore ultra wash model 16625691
looking for a black/almond front replacement panel for my Kenmore dishwasher model #16625691. Any sugguestions as to where to find one?
Oct 17, 2007 | Hobart AM14-253 Free-standing Dishwasher
Dishwashers Logo
259 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
